How many cubes is one robot aloud to hold, in the new skyrise game? :o
check the rules.
We check and didn’t see how many it only said we can can hold one skyrise section at a time but not about the cubes.
If there isn’t a limit on object possession SPECIFICALLY STATED in the manual, you can hold as many as you can build the robot to carry. There IS a rule in the manual that says “You can only carry one Skyrise Section.” But that rule has NOTHING to say about the Cubes, and there is NO rule limiting their number. So, in this year’s game, you can theoretically carry 44 Cubes. It’s exactly the same as with large balls in Toss Up, or, you know, every game object in every year previous.
If it’s not stated in the rules that means it’s as many as you can hold.
It’s a max capacity game, just like Sack Attack.
Ok thank you. I will remeber this in future games.
I plan on holding 6 to 8 cubes
with an intake like some teams used in gateway that expanded
Each cube is 8", so to hold 8 cubes, your intake will have to be 64" long. I won’t say that holding 8 isn’t possible, but I would find a better way to do it.
I think 2-3 cubes at max for the bot to be fast.
How big are the cubes
The Cubes are 8 inches
For all the game dimensions, weights, etc…[REMOVED LINK]
EDIT: Sorry, I meant the field specifications found here. (VEX Skyrise - Appendix A (Field Drawings, Specifications & BOM))
