Cube Locking Mechanism
Teams that have a mechanism that holds cubes in the tray when you lift the arm up, how often do you take advantage of this feature. We are considering adding one, but are not sure if it is really that useful or that much of an advantage.
It’s most useful in skills, since it gives you a lot more freedom when routing, but it can still be useful in matches.
@Anomalocaris
How often do you use it during a match?
We don’t have one personally, but our sister team does, and they don’t use it often. From a strategic standpoint, unless there is a cluster of cubes of the color you want to place in towers after stacking, it probably isn’t worth it to go around the field to grab multiple at once before placing in towers. The only thing we really want to build one for is skills.
