Your Victor884 product description states “PWM deadband effect can be overridden”. How is this accomplished? I can generate very high resolution PWM pulse widths, but everything inside the deadband generates no output!
Any value that is sent, that is valid in the Dead-Band Range will cause the Victor to be in Neutral. To eliminate the Dead-Band, you must only send values that are valid as a Forward or Reverse condition. Therefore, the motor connected to the Victor will always be trying to turn in either the Forward or Reverse direction.
