I have two V5 batteries that appear to be dead and will not charge. I have read several post and tried a number of solutions but having no luck. Tried charging for several hours, no lights. Tried resetting with no success. The batteries are only 1 yr. old.
Perhaps it’s not the battery or the charger, but maybe you have a faulty outlet. Have you tried charging at different outlets?
Contact Vex support; they will likely issue you an RMA. Send the battery back and they’ll send a new one
I just had the same issue
RMA the battery to VEX got a new battery
I have power i have been charging the others from the same outlet
That is a good suggestion thank you
