We are having trouble with sensor values not showing up in the RobotC debug stream window. My computer, running windows 10 and RobotC 4.54 works. Students running 4.55 don’t seem to be able to see their sensors. Any idea if there is something we are missing and can use to check/debug the debugger?
Not sure of you meant values sent using “writeDebugStream” or just sensor values in the sensor debug window, either way, RobotC V4.54 and V4.55 are almost identical (we just removed the licensing and fixed one other small bug) so they should behave the same. Perhaps the menu level is set differently (basic, expert etc.), that can disable some of the debug window choices.
