Im trying to control an intake motor seperately from my drivetrain in EZ template. However im getting several match call errors.
void opcontrol() {
pros::Motor intake(6);
if (master.get_digital(DIGITAL_A)){
intake = -127;
else if(master.get_digital.(DIGITAL_A)){
intake = 0;
It looks like there are a few issues:
- The second time you call
you accidentally put a .
after master.get_digital
. This will cause a compiling error.
- Using
intake =
voltage;
no longer works in PROS. You should use intake.move(
voltage);
. For example spinning the intake backward at full speed would be intake.move(-127);
- Currently your conditionals that manage the intake seem to be checked only once. Any code that reacts to a button press should be run in a loop (i.e.
while(true) { }
) (Don’t forget to put a small delay in the loop so that your brain has time to perform other processes.)
A great place to learn about how PROS works is… their own documentation.
PROS documentation
PROS 4 C++ motor movement functions
Thanks. I totally shouldve notice the extra period, but I guess my dyslexia was getting to my late at night. Thanks.
