I’m having some issues declaring arrays in vcs. For instance:
int NamesArray[] = [“name1”,“name2”,“name3”,“name4”,“name5”,“name6”];
will give me an error:
expected variable name or ‘this’ in lambda capture list int blueNamesArray[] = [“name1”,“name2”,“name3”,“name4”,“name5”,“name6”];
I’m probably missing something very simple. Any help?
I’m guessing you are coming from js or something?
The C++ syntax to initializing an array is
int array[] = {1, 2, 3, 4, 5};
However, you can’t assign a string to an integer, array or not.
Instead, you can use const char*
(the C way) or std::string
(the C++ way) to store the string.
You are trying to store Strings in an int array, primitive data to object will not work out. Plus, use curly braces, so:
String[] names = {“name”, “name”, “name”};
etc. Or to fill it later, do this:
String[] names = new String[length]
But remember, array length is immutable
Thanks for the help, and yes I’ve been using js.
I’m pretty sure you are mixing up another language.
A String
object does not exist in C, and the new
command does not work in the way you think (it does dynamic initialization which returns a pointer).
This is the use of new
int* array = new int[length];
array[0] = 1;
Read here and here.
The way a string is represented is an array of char
, so const char*
is how they do it in C.
std::string
is a wrapper for this, which is object oriented and much nicer.
Fortunately,
std::string array[] = {"hello", "goodbye"};
is valid syntax.
@Palpatine I would look into reading some C/C++ guides. These languages are quite a bit less intuitive than js, and require some lower level management. You just can’t be as flexible as js.
The only time you are able to use the = {1, 2}
syntax is on initialization.
You can’t do
int array[];
array = {1, 2, 3};
The size of the array can only be controlled when the array is created.
The solution people use is to make use of std::vector
, which is a resiable array. here and here.
Then, you can do
std::vector<std::string> array = {"hello", "goodbye"};
array.push_back("greetings");
array = {"hi"};
This is a much better solution than to use new
Yeah my bad. I was teaching about java earlier, slipped my mind.
