I know that you are able to delete all programs from the brain by going to settings>delete programs.
Is there a way to delete only 1 program at a time? (It may be something really obvious I’m missing)
Thanks in advance!
Thanks in advance!
Is it just for visual looks or for actual reason
Just looks. I know you can simply overwrite them by setting the port number on vexcode
Yah that’s what I was gonna say. Otherwise I don’t think so. Just delete all and then redownload
This is NOT possible, sadly
So it’s technically possible, we have the commands available in the control protocol, but unfortunately VEXcode has not implemented that feature and we didn’t add anything into the UI that could be used to do this, we can consider adding in a future vexos update.
