Detaching Walls
Alright so is a detaching stuff aloud.
My team made this(https://www.instagram.com/p/B4N7KpnBnBB/?igshid=keomaaig0q1i) and I was wondering if it’s legal to just drop it and drive off.
Or if it has to be attached to the robot it and can it be a string?
you can’t seperate your bot, you need some sort of tether.
No, <G5>
But can the tether be a string or does it have to be structure pieces
You can use string I believe. However it is illegal to just drop and run.
entanglement hazards are your biggest enemy, if you can make a string that cannot be tangled its good, but that can be hard. one good method could be using polycarb segments that lay flush on the tiles
Alright, thank you! (20 characters)
