Every planetary transmission/differential transmission I’ve seen on here would need some kind of lock for the high-torque mode to actually work. That lock would probably be pneumatics.
So the advantage to the transmissions that you’ve seen here is not that they don’t need pneumatics, it’s that they transition smoothly from one gear to the next. There is no disengaging gears and then reengaging gears. All of the gears stay engaged, you just change the directions of the inputs.
The simple gear-sliding transmissions I think are still better than (although not as cool as) the planetary/differential ones. There are very efficient ways to make a gear-sliding transmission that only involve adding two axles between the motor and the wheel.
he was talking about settings high speed high torque
planetaries without a secondary mechanism only have 2 settings
motor1 forward motor2 backward
motor1 forward motor2 forward
Yes, this. How does the cylinder shift the axles? I’d be interested to see how specifically you did that (I have my own ideas, but I’ve never actually seen one of these before).
You could take out the first two axles and replace them with chain and a sprocket that slides on the shifting axle (it’s a little narrower than the sliding gear).
wasnt me this is team 10d
there are c channels on each side the c channels have 1 by 25s between the two gears
so when it pushes it pushes one side 1 inch hits wall and pushed other side 1 ince
