How does one program a LCD to show the Sensor value of let’s say a potentiometer. (Sorry if misspelled)
Displaying Sensor Values on LCD's
kypyro
#2
I usually put the sensor value into a string and then display that. The following example reads a sensor port and displays the raw value on the first line of the LCD and a converted value on the second line.
The comments may help you understand what’s going on. The comments are, of course, non-functional.
// declare some string variables to hold the formatted information
string outLine1 // this will hold what we want on the first line of LCD
string outLine2; // this will hold what we want on second line of LCD
int mySensorValue;
// expanderPort is configured as an analog sensor in Motors and Sensor setup
// we plugged an extension cable between the power expander status port and the analog port
// read the value
mySensorValue = SensorValue[expanderPort];
// format the value into a string
sprintf(outLine1,"sensor is: %d",mySensorValue);
// turn the integer value from sensor port into a floating point value
// representing volts of the battery plugged into the power expander.
// Then, format the information for printing. The "%f" in the format
// string will be replaced by the floating point number calculated by the
// division.
sprintf(outLine2," %f Volts",(float)mySensorValue/270.0);
clearLCDLine(0);
clearLCDLine(1);
displayLCDString(0,0,outLine1);
displayLCDString(1,0,outLine2);
For your purposes, you could either define the analog port as a potentiometer or just set it to “analog”. It won’t change how you use the port.
