Do I have to use Okapi for Autonomous
I deleted the Okapi Lib earlier on because the file was too big with it and it wouldnt upload to the brain. I am coding for autonomous and it is working although there are a few bugs. Would I have to switch to coding in Okapi? Like for tournaments and stuff and just vex overall is it ok to have my autonomous code in main.cpp?
…what? ​​​​​​​​​​​​​​​​​
Like do I have to code the autonomous in the Okapi Lib?
OkapiLib is a library that helps teams have an easy way to code autons. However, it is not needed and you should be fine if you code within the β€œautonomous” void of main.cpp.
Extra note: If you want to make it a bit more organized I would suggest creating a whole new .cpp file for only your autons as it will get very cluttered if in the main.cpp area.
Another Extra Note: When first uploading a pros program to the brain you will need to plug it in directly with the USB cable. The file is quite large and won’t have a fun time sending wirelessly.
No, you don’t need to use Okapi Lib to code auton in VEXcode or PROS.
