It does appear you’re talking about skills. The red goals will start in the blue side and vice versa. You should start with 0 points at the start of a skills match. And each goal scored in the home zone is worth 20 points.
In a tournament match, the all the alliance goals start on their colored side. If nobody moved, each alliance will finish with 40 points each.
I’m pretty sure that the mobile goals are worth 30. If a mobile goal Ends Match in either Alliance Home Zone - 30 Points. (in LRT matches) I guess the question is: are all mobile goals worth points if they are in the home zone or only the neutral mobile goals? Becuase if allience mobile goals are worth points in the home zone then your start with 120 points.
a elevated robot is worth 30 but not a moblie goal. they are ethier 20 points not elevated or 40 points elevated ( of course it is more if you have rings on the goal but im talking the basics)
with the LRT, i have never done one, but i can assume skills are the same. So if your skills was set up to where the alliance goals are on their own side (red or blue) the person who did your tourntament had done it wrong. if you stay idle in skills, the amount of points should be 0
Goals in the neutral zone are worth 10 points and goals are worth 30 points in either home zone. So unless the yellow goals start elsewhere, you should have 150 points by default I think.
