Just wondering if you think it would work. ( This is in a competition template )
void usercontrol(void) {
while(true){
//Foward
leftmotor.spin(forward, Controller1.Axis3.value()+
rightmotor.spin(forward, Controller1.Axis2.value()+
//Backward
leftmotor.spin(reverse, Controller1.Axis3.value()-
rightmotor.spin(reverse, Controller1.Axis2.value()-
//Lift Up
leftlift.spin(forward, Controller1.ButtonL1.pressing()+
rightlift.spin(forward, Controller1.ButtonL1.pressing()+
//Lift Down
leftlift.spin(forward, Controller1.ButtonR1.pressing()-
rightlift.spin(forward, Controller1.ButtonR1.pressing()-
Deicer
November 6, 2019, 10:54pm
2
No because you don’t close any of your motor spin commands’ parenthases
Also there arent any semicolons
Also need semicolons after most of the lines
How would i close the commands?
(I forget how to do the code tags but)
It should have a parenthesis and semicolon after it like this
leftmotor.spin(forward, Controller1.Axis3.value()+);
rightmotor.spin(forward, Controller1.Axis2.value()+);
when i try this, it comes up as an
{clang} Expected expression
Deicer
November 7, 2019, 1:11am
8
Example:
leftmotor.spin(forward, Controller1.Axis3.value());
I’m not sure if this is a necessity, but I also always add units like so:
leftmotor.spin(forward, Controller1.Axis3.value(), pct);
would this make it so the stick going toward the top makes the motor go forward and when the joystick goes down it will go in reverse?
I’m using your
Yes that is correct
(20 characters)
