Does any one know why everything but the wheels are not functioning with the Vex controller
The hardware is up to date i’m thinking it could do something with the while statements.
#pragma config(Motor, port2, frontRight, tmotorVex393_MC29, openLoop)
#pragma config(Motor, port3, backRight, tmotorVex393_MC29, openLoop)
#pragma config(Motor, port4, frontLeft, tmotorVex393_MC29, openLoop, reversed)
#pragma config(Motor, port5, backLeft, tmotorVex393_MC29, openLoop, reversed, encoderPort, None)
#pragma config(Motor, port6, beltMotor, tmotorVex393_MC29, openLoop)
#pragma config(Motor, port7, rotationMotor, tmotorVex393_MC29, openLoop)
#pragma config(Motor, port8, clawMotor, tmotorVex393_MC29, openLoop, encoderPort, None)
#pragma config(Motor, port9, armMotor, tmotorVex393_MC29, openLoop)
/*+++++++++++++++++++++++++++++++++++++++++++++| Notes |++++++++++++++++++++++++++++++++++++++++++++
  • The left joystick Y-axis controls the robot’s forward and backward movement.
  • The left joystick X-axis controls the robot’s left and right movement.
  • The right joystick X-axis controls the robot’s rotation.
  • The Code incorportes a threshold/deadzone that allows very low Joystick values to be ignored.
    This allows the robot to ignore values from the Joysticks when they fail to center at 0,
    and provides a margin of error for the driver when they only want the robot to move in one axis.
[I/O Port] [Name] [Type] [Description]
Motor Port 2 frontRight VEX Motor Front Right motor
Motor Port 3 backRight VEX Motor Back Right motor
Motor Port 4 frontLeft VEX Motor Front Left motor
Motor Port 5 backLeft VEX Motor Back Left motor
task main()
//Loop Forever
while(1 == 1)
//Remote Control Commands
motor[frontRight] = vexRT[Ch3] - vexRT[Ch1] - vexRT[Ch4];
motor[backRight] = vexRT[Ch3] - vexRT[Ch1] + vexRT[Ch4];
motor[frontLeft] = vexRT[Ch3] + vexRT[Ch1] + vexRT[Ch4];
motor[backLeft] = vexRT[Ch3] + vexRT[Ch1] - vexRT[Ch4];
////________________________________________________________________________________________________________
//above is the code for the wheels which allows wheels to move in a 350 degrees rotation.
if(vexRT[Btn7U] == 1)       	//If button 7U is pressed...
	motor[armMotor] = 127;    	//...raise the arm.
else if(vexRT[Btn7D] == 1)  	//Else, if button 7D is pressed...
	motor[armMotor] = -127;   	//...lower the arm.
else                      		//Else (neither button is pressed)...
	motor[armMotor] = 0;      	//...stop the arm.
//////______________________________________________________________________________________________________
//above is the code for the arm which allows it to move up and down
// Open, close or do not more claw
if(vexRT[Btn6U] == 1)       	//If Button 6U is pressed...
	motor[clawMotor] = 127;  		//...close the gripper.
else if(vexRT[Btn6D] == 1)  	//Else, if button 6D is pressed...
	motor[clawMotor] = -127; 		//...open the gripper.
	motor[clawMotor] = 0;    		//...stop the gripper.
////_______________________________________________________________________________________________________________
//above is the code for the claw allowing it to open and close
if(vexRT[Btn7L] ==1)			//If button 7L is pressed
	motor[beltMotor] = 127;  		//Move the Conveyor belt forward
else if(vexRT[Btn7R] == 1)  	//Else, if button 7R is pressed...
	motor[beltMotor] = -127; 		//Move the Conveyer belt backwards.
	motor[beltMotor] = 0;    		//...stop the Belt.
//above is the code for the conveyor belt allowing it to move back and forth
if(vexRT[Btn8R] ==1)			//If button 8R is pressed
	motor[rotationMotor] = 63;  		//Rotates the claw
else if(vexRT[Btn8L] == 1)  	//Else, if button 8L is pressed...
	motor[rotationMotor] = -63; 		//Move the Conveyer belt backwards.
	motor[rotationMotor] = 0;    		//Dont rotate
Is that… not in the while loop? Doesn’t the while loop end right after the motor FR BR FL BL?
Try moving the } from after those 4 lines to the very end.
Its working now thank you for your help
