Does the cortex matter?
My team is making a competition robot and are having some issues like drive motors starting one at a time and vex net keys not connecting
Ive been searching the internet for months and am starting to feel incompetent. So I was wondering is the fact we are using a vex EDR cortex the problem?
The Cortex works fine, POST SOME CODE or we cannot help you.
#pragma config(Motor, port2, frontRight, tmotorVex393HighSpeed_MC29, openLoop, driveRight)
#pragma config(Motor, port3, backRight, tmotorVex393HighSpeed_MC29, openLoop, driveRight)
#pragma config(Motor, port4, frontLeft, tmotorVex393HighSpeed_MC29, openLoop, driveLeft)
#pragma config(Motor, port5, backLeft, tmotorVex393HighSpeed_MC29, openLoop, driveLeft)
#pragma config(Motor, port6, armMotorleft, tmotorVex393_MC29, openLoop)
#pragma config(Motor, port7, armMotorright, tmotorVex393_MC29, openLoop)
#pragma config(Motor, port8, Pickupmotor, tmotorServoContinuousRotation, openLoop)
#pragma config(Motor, port9, lockMotor, tmotorServoStandard, openLoop)
task armLeft()(I have a code now for the arm I haven’t been able to test)
while (true)
if(vexRT[Btn6U] == 1)
  motor[armMotorleft] = 127;
else
    if(vexRT[Btn6D] == 1)
  motor[armMotorleft] = -127;
else
  motor[armMotorleft] = 0;
waitInMilliseconds(10);
task armRight()
while (true)
  motor[armMotorright] = 127;
else if(vexRT[Btn6U] == 1)
  motor[armMotorright] = -127;
else
  motor[armMotorright] = 0;
task pickup()(I’m going to try to use the same code here)
while (true)
if(vexRT[Btn5U] == 1)
  motor[Pickupmotor] = 127;
else if(vexRT[Btn5D] == 1)
  motor[Pickupmotor] = -127;
else
  motor[Pickupmotor] = 0;
task lock()(I haven’t been able to test the positions yet either)
while (true)
    if(vexRT[Btn7L] == 1)       //If the group 7 left button is pressed
        motor[lockMotor] = 127;     //then lock the axel
    else if(vexRT[Btn7R] == 1)  //But if the group 7 right button is pressed
        motor[lockMotor] = -127;    //then unlock the axel
    else                        //But if no button is pressed
        motor[lockMotor] = 0;      //stop the servo.
task main()
//Loop Forever
startTask(armLeft);
startTask(armRight);
startTask(pickup);
startTask(lock);
while(1 == 1)
    //Remote Control Commands**(I'm hopefully getting help with this)**
motor[frontRight] = vexRT[Ch3] - vexRT[Ch1] + vexRT[Ch4];
motor[backRight] = vexRT[Ch3] - vexRT[Ch1] - vexRT[Ch4];
motor[frontLeft] = vexRT[Ch3] + vexRT[Ch1] - vexRT[Ch4];
motor[backLeft] = vexRT[Ch3] + vexRT[Ch1] + vexRT[Ch4];
//one motor needs to be reversed
So I’m not really sure what you question is, the code was more or less correct, one small mistake in the armRight task (checking Btn6U twice), but otherwise worked.
VEXnet keys not connecting is unrelated to code, it’s been common with the old black keys for a long time. The new white keys are better.
What do you means by drive motors starting one at a time?
Here is your code revised, reformatted and the (only) natural language call replaced with the standard one, wait1Msec.
Use code tags when posting code, it makes reading it easier and keeps the formatting.
//*!!Code automatically generated by 'ROBOTC' configuration wizard !!*//
task armLeft()
    while (true)
        else
        else
        wait1Msec(10);
task armRight()
    while (true)
        else
        else
        wait1Msec(10);
task pickup()
    while (true)
        else
        else
        wait1Msec(10);
task lock()
    while (true)
        else
        wait1Msec(10);
task main()
    // Start tasks
    startTask(armLeft);
    startTask(pickup);
    startTask(lock);
    //Loop Forever
    while(1 == 1)
        //Remote Control Commands(I'm hopefully getting help with this)
        wait1Msec(10);
