The solenoid valve leaks 0.1 psi every second, and it seems to be the solenoid’s problem. We replaced fittings and narrowed the leak to the solenoid’s problem. Why does this happen? What can we do to fix it?
use Teflon tape on the threads
Try listening to see where the leak is for some hissing. Either that or put a tiny bit if soap water on the joints to look for bubbles.
Also,
