Our team built the double reverse 4-bar linkage as lift. It works well if we use hand to lift the structure up. However, if we use motor, the motor gets hot but the structure fails to lift up. Is it possible that double reverse 4-bar is too heavy that we need two motors (in-sync) to drive the structure?
Note that we have successfully built and used 6-bar linkage lift with single motor. It worked well. don’t know if the extra pieces used on double reverse 4-bar made it too heavy?
Your inputs are welcome!
