dr4b tilting.
If it comes to it, I would drill a set of holes through a 5 wide c channel where you need to line up the holes. I wouldn’t try to drill a 2 wide because it would lose its stability much faster than a 5 wide when it comes to drilling holes.
We would probably only do this if we are sure that the problem is lack of supports.
This also happens in other lifts. I saw an eight bar and a rack and pinion powered scissor lift both have one side go slower than the other. Who knows whats the main solution…
Yeah my guess is that there is a lack of rubber band support so when there is more weight (2 cubes) in the exact middle the motors work harder and short out because there is a lack of rubber bands. Sadly we have ran out of rubber bands so the first thing I am going to try is adding more.
I agree. Lack of rubber bands are the solution. Do you think that when the motors work harder and short out this causes permanent damage to them, even if it’s a little?
I think you meant lack of rubber bands you the problem. :stuck_out_tongue:
I think it’ll damage the internal gears a bit, though that happens with wear and tear. The motor shorting out can cause issues with the motor controllers I believe.
Yeah I was testing it and when ever we would lift the motors would go and then half way through start shorting and then completely just die so I put the lift on a power expander and I’m going to switch the motor controllers tomorrow and see if that helps. As far as bracing goes I replaced all the old bracing with steel and added more. As well as added a couple new parrellel braces on the top arm. I aslso changed the spacing slightly with the top lift because I realized it was bowing by 1/16th of an inch. And i added more rubber bands equaly. All of these solutions seemed to improve the problem but not by much and it still has trouble going down. I may be able to upload a video later.
We’ve seen the bottom bars being steel allows for less flex and twist than aluminum. Yes it’s more weight, but the twist is what is killing you it seems.
Alternating directions of those lower bars seems to help but makes for a tricky connection. Also making another set of parallel bars (like you were building a 6 bar but just staying with the 4 bar) can help.
Going sideways on the c-channels gives less flex too. See 80P’s as an example. Uses a bit more room but it twists less. 80Y did the same thing.
80P Pyro DR4B in action
A sync shaft between the two sides would also help as the twist may be caused by the motors running at slightly different speeds.
Then you can attack the front lower connection points. Very small variances there lead to much larger variances further up the double reverse four bar.
80A braced their front a heck of a lot to just that.
IMG_0324
Power expander can be a bit tricky and may not solve your problems. Don’t think of it as a complete solution to your power needs because the motors still trip with the same current it sees no matter where it is sourced from. If you don’t have enough rubber bands (or they are totally slack up top) the motor will still require too much current and trip the PTC.
I like the idea of steel instead of aluminum but im still in the process of figuring out weather its supports or something else because I added a lot of supports and double checked everything but the problem is still occurring.
We seemed to have solved our problem with tilting by doing multiple things. The first thing we did was take off our swing are mounted on our intake, we did this because I found that it had to much weight up top meaning when we would raise it would start slightly tilting but then the weight on top would pull the rest of the lift down causing it to tilt more. Upon taking off the swing arm and its structure our lift raise fairly straight with 2 cubes but when the arm would lower it would tilt the same, to fix this we changed the motors (again) on the weaker side. We also kept our cross beams and added “I” supports
Instead of mounting them in the same place we took of the bearing flats and moved them to the inside, this gave us enough room to put IME’s on the motors. With out any coding our lift lowered a little bit straighter but still had tilting problems. After coding the lift raised and lowered perfectly but it presumed other problems.
All of a sudden the right side of the drive will completely cut out, as if the PTC was shutting off the motor, but when we would take the robot off the ground and run the motors they ran fine (we even grabbed them trying to activate the PTC and it seemed to take a lot of force). When driving it felt as if one of the motors were out but when testing they worked perfectly fine. Any Ideas why?
We had a similar problem earlier, what ended up happening was that the metal supporting the gears had been bent from the previous tilting causing it to occur more often due to a slight misalignment. You should try double checking the gears if you haven’t already, as well as test the motors powering the lift.
The lift seems fine now and just in the nick of time too (they were shipped earlier today), But we are seeing some drive problems that never occurred. It seems as tho the motors are reaching their max power and shutting off, but this has never happened before even when we had more weight on the robot. The only thing that makes me think is causing the problem is because of the IME’s on the lift being connected to the IME’s on the drive but I don’t know if that is even possible.
What is your motor setup on the cortex?
Is this happening in autonomous or driver control?
