Taking a page from the virtual robot program that lets you draw. We’ve started making a robot that will lower and raise a dry erase marker so we can write on the floor.
Our goal is to write some words of encouragement around the school. Anyone try to do this with a physical robot?
Biggest issue i can see, is having the rotation messed up. So instead of a straight line of text it gets curved, and distorted. Any advice?
Well I guess if you found the dimensions of the marker and come up with something to hold the marker, all you need to make it do in the simplest form is go up and down and rotate side to side.
Your first sponsor of this should be your head custodian at your school. Writing on the floors is a huge hassle for them, it makes their job much harder. “Think of unintended consequences”
