Drive Code Only Driving Forward
Hi! I’m at worlds right now, and my partner is having trouble getting his drive code to work. Like the title indicates, it is only driving forward. Here’s the code:
/*    Module:       main.cpp                                                  */
/*    Author:       VEX                                                       */
/*    Created:      Thu Sep 26 2019                                           */
/*    Description:  Competition Template                                      */
// Robot Configuration:
// [Name]               [Type]        [Port(s)]
// Drivetrain           drivetrain    7, 10, 20, 19
// lift                 motor         9
// ring                 motor         18
// fourbar              motor         8
// pp                   digital_out   A
// Controller1          controller
#include "vex.h"
using namespace vex;
competition Competition;
using signature = vision::signature;
using code = vision::code;
// A global instance of brain used for printing to the V5 Brain screen
brain  Brain;
// VEXcode device constructors
motor leftMotorA = motor(PORT13, ratio6_1, true);
motor leftMotorB = motor(PORT12, ratio6_1, true);
motor leftMotorC = motor(PORT11, ratio6_1, true);
motor_group LeftDriveSmart = motor_group(leftMotorA, leftMotorB , leftMotorC);
motor rightMotorA = motor(PORT18, ratio6_1, false);
motor rightMotorB = motor(PORT19, ratio6_1, false);
motor rightMotorC = motor(PORT20, ratio6_1, false);
motor_group RightDriveSmart = motor_group(rightMotorA, rightMotorB, rightMotorC);
drivetrain Drivetrain = drivetrain(LeftDriveSmart, RightDriveSmart, 319.19, 295, 40, mm, 1);
motor lift = motor(PORT9, ratio36_1, false);
motor ring = motor(PORT1, ratio6_1, true);
motor fourbar = motor(PORT10, ratio36_1, false);
digital_out pp = digital_out(Brain.ThreeWirePort.A);
digital_out penis = digital_out(Brain.ThreeWirePort.B);
digital_out daddy_jobe = digital_out(Brain.ThreeWirePort.C);
digital_out mega_nut = digital_out(Brain.ThreeWirePort.D);
controller Controller1 = controller(primary);
// VEXcode generated functions
// define variable for remote controller enable/disable
bool RemoteControlCodeEnabled = true;
// define variables used for controlling motors based on controller inputs
bool Controller1LeftShoulderControlMotorsStopped = true;
bool Controller1UpDownButtonsControlMotorsStopped = true;
bool Controller1XBButtonsControlMotorsStopped = true;
bool DrivetrainLNeedsToBeStopped_Controller1 = true;
bool DrivetrainRNeedsToBeStopped_Controller1 = true;
/*                          Pre-Autonomous Functions                         */
/*  You may want to perform some actions before the competition starts.      */
/*  Do them in the following function.  You must return from this function   */
/*  or the autonomous and usercontrol tasks will not be started.  This       */
/*  function is only called once after the V5 has been powered on and        */
/*  not every time that the robot is disabled.                               */
void pre_auton(void) {
  //vexcodeInit();
/*                              Autonomous Task                              */
/*  This task is used to control your robot during the autonomous phase of   */
/*  a VEX Competition.                                                       */
/*  You must modify the code to add your own robot specific commands here.   */
void autonomous(void) {
  // Insert autonomous user code here.
/*                              User Control Task                            */
/*  This task is used to control your robot during the user control phase of */
void usercontrol(void) {
  while (1) {
    // This is the main execution loop for the user control program.
    // Each time through the loop your program should update motor + servo
    // values based on feedback from the joysticks.
    if(RemoteControlCodeEnabled) {
      leftMotorA.setVelocity(100, pct);
      leftMotorB.setVelocity(100, pct);
      leftMotorC.setVelocity(100, pct);
      rightMotorA.setVelocity(100, pct);
      rightMotorB.setVelocity(100, pct);
      rightMotorC.setVelocity(100, pct);
      lift.setVelocity(100, pct);
      fourbar.setVelocity(100, pct);
      // calculate the drivetrain motor velocities from the controller joystick axies
      // left = Axis3 + Axis1
      // right = Axis3 - Axis1
      int drivetrainLeftSideSpeed = Controller1.Axis3.position() + Controller1.Axis1.position();
    int drivetrainRightSideSpeed = Controller1.Axis3.position() - Controller1.Axis1.position();
      // check if the value is inside of the deadband range
      if (drivetrainLeftSideSpeed < 5 && drivetrainLeftSideSpeed > -5) {
        // check if the left motor has already been stopped
        if (DrivetrainLNeedsToBeStopped_Controller1) {
          // stop the left drive motor
          LeftDriveSmart.stop();
          // tell the code that the left motor has been stopped
          DrivetrainLNeedsToBeStopped_Controller1 = false;
      } else {
        // reset the toggle so that the deadband code knows to stop the left motor nexttime the input is in the deadband range
      if (drivetrainRightSideSpeed < 5 && drivetrainRightSideSpeed > -5) {
        // check if the right motor has already been stopped
        if (DrivetrainRNeedsToBeStopped_Controller1) {
          // stop the right drive motor
          RightDriveSmart.stop();
          // tell the code that the right motor has been stopped
          DrivetrainRNeedsToBeStopped_Controller1 = false;
      } else {
        // reset the toggle so that the deadband code knows to stop the right motor next time the input is in the deadband range
      // only tell the left drive motor to spin if the values are not in the deadband range
        LeftDriveSmart.setVelocity(drivetrainLeftSideSpeed, percent);
        LeftDriveSmart.spin(forward);
      // only tell the right drive motor to spin if the values are not in the deadband range
        RightDriveSmart.setVelocity(drivetrainRightSideSpeed, percent);
        RightDriveSmart.spin(forward);
      // check the ButtonL1/ButtonL2 status to control fourbar
      if (Controller1.ButtonL1.pressing()) {
        fourbar.setVelocity(100,pct);
        fourbar.spin(forward);
        Controller1LeftShoulderControlMotorsStopped = false;
      } else if (Controller1.ButtonL2.pressing()) {
        fourbar.spin(reverse);
      } else if (!Controller1LeftShoulderControlMotorsStopped) {
        fourbar.stop(brakeType::hold);
        // set the toggle so that we don't constantly tell the motor to stop when the buttons are released
      // check the ButtonUp/ButtonDown status to control lift
      // check the ButtonX/ButtonB status to control ring
      if (Controller1.ButtonR1.pressing()) {
        ring.setVelocity(100,pct);
        ring.spin(reverse);
        Controller1XBButtonsControlMotorsStopped = false;
      } else if (Controller1.ButtonR2.pressing()) {
        ring.spin(forward);
      } else if (!Controller1XBButtonsControlMotorsStopped) {
        ring.stop();
      //pp
      if (Controller1.ButtonUp.pressing()) {
        pp.set(true);
      } else if (Controller1.ButtonDown.pressing()) {
        pp.set(false);
        if (Controller1.ButtonA.pressing()) {
        penis.set(true);
      } else if (Controller1.ButtonY.pressing()) {
        penis.set(false);
        if (Controller1.ButtonX.pressing()) {
        daddy_jobe.set(true);
      } else if (Controller1.ButtonB.pressing()) {
        daddy_jobe.set(false);
        mega_nut.set(true);
        mega_nut.set(false);
    // wait before repeating the process
    wait(20, msec);
    // Insert user code here. This is where you use the joystick values to
    // update your motors, etc.
     // Sleep the task for a short amount of time to
                    // prevent wasted resources.
// Main will set up the competition functions and callbacks.
int main() {
  // Set up callbacks for autonomous and driver control periods.
  // Run the pre-autonomous function.
  pre_auton();
  // Prevent main from exiting with an infinite loop.
  while (true) {
    wait(100, msec);
If you are at worlds, feel free to stop by software support. We have several people here that would be happy to work through your issue with you. We are located next to the arts division fields.
