Drive Codes VEXcode v5 pro (text)
What would be the code used to make your robot turn 75 or any amount of degrees, if each drive motor is programmed separately instead of using a drive train?
Welcome to the forums!
In order to do that you would probably have to make your own PID function using a gyro sensor.
Hers a link with more information:
