The lift on our robot last year was a 6-bar. But we found that the vex drive shafts wren’t able to keep up with the torque of the motors and rather than rotating the gears and lifting the mechanism, the shafts would just twist and snap in two.
Does anyone else have this problem? How did you deal with it?
Any recommendations as to where we can buy stronger drive shafts the same size as VEX’s?
Was the shaft that twisted attached to your motor or the gear that drove the arm? If it was attached to the arm, was it taking all of the torque of the arm (was the shaft in a gear that was being turned and then the shaft was attached to the arm via a lock bar etc)?
You should always mount any structures to the gears and not the axles. If you have a 30 inch arm with an intake at the end, even using aluminum, you have a lot of torque. Too much much torque to attach the structure to the axle. The axles should only be used as pivot points for supporting your structure.
Motors don’t even have close to the torque required to twist as axle.
The only explanations I can think of are:
It’s a new 269 and the motor locked up, then the arm was forced into the down position.
-or-
There is another source of torque on that axle (another motor for example) that is contributing.
