Our team has been having issues with our drive. After about 30 seconds of driving, our drive stalls. This only happens on the competition foam tiles and we checked for excess friction. Our drive is an all omni-wheel direct powered with 393’s set to torque. We suspect that we are tripping our breakers.
Is there any way to fix this? Help would be very greatly appreciated.
If the cortex is tripping, you want to try spreading out the motors over the different circuit breakers. On the cortex, ports 1-5 are on a separate breaker than ports 6-10, so if you balance drive motors between those (and a power expander if you have one) that might help.
If those motors are more than 2 years old, or strained with a previously faster ratio, they probably degraded to the point of replacement. The only way you can fix that is to replace the motors. How many motors do you have on the drive train, and what is your weight(approximate if needed)?
That’s not true. Earlier this season, I put one high speed motor on one side of the drive, and a normal speed on the other side. Kept burning out until I swapped out the low speed to be another high speed.
Based on what you’re telling us, there is absolutely no reason for your drive to be burning out. Which means you’re missing something. Is it possible your intake tray is dragging on the ground? Are the motors on your intake dragging? Anything like that?
Is it possible that you have too many spacers on the axle, causing friction as it spins? You might not see that if you tested for friction like we sometimes do, before everything is spaced correctly.
Are you using Delrin Bearings? That helps a little bit.
Are your wheels cantilevered, or braced on both sides? We’ve had problems with drives stalling in the past when we cantilevered the wheels.
My drivetrain guy wants me to test your motors, just to make sure those aren’t the problem. Here’s the way he suggests.
Take the motors one by one off of the wheels on your chassis, and put an axle with just a wheel on them. Power the motor with a backup battery by plugging the ports into the Backup Battery Cable. Stop it by hand, and see if any of them die really quickly. After they’re stalled, wait five seconds and see if they start spinning at full speed again. If one spins less than the others, then there’s your problem. If they all go back to full speed immediately, then we move onto something else.
Good, that’s what you should see. That right there is why after the first time you stall your base, it happens more and more frequently. So now we need to figure out why it happens the first time.
Does it burn out crossing the bump, or even just driving across the flat area of the middle and goal zones?
EDIT: Can you just post a couple pictures of the base? That might make this easier.
You have a friction issue! We had a 27lb. robot our first season using 4 393’s geared for torque and didn’t stall. Are you using omni wheels, mecanums, or high traction wheels? Also is your base square? When I say square I men if you measure from one corner to the other diagonally on each side is it the same for both measurements? Are you in League City already? I assume you are competing there tomorrow and not driving in from the Valley in the morning.
My bad, I overlooked the omni’s. Spinning the wheels does not rule out friction from extrinsic factors such as wheel camber or asymmetry of the base. That is about all I can think of, I cannot imagine 4 HT 393’s stalling that fast. I would wonder if the wheels are all powered and turning the same speed. Our scissor lift weighed 19-1/2 lbs and never stalled with 4 393’s.
I do have a square base and I am already in League City, after we passed inspection we tested it on the practice field. This was when we noticed our problem.
