Is it possible and as accurate to create a drive straight program that corrects using an inertial sensor heading value As the inertial sensor heading value is always positive (0-360),instead of two encoders on each side of the robot.
or use rotation() which does not roll over from 359.9 to 0. You could set rotation to 0, it will then return +/- values depending of you have rotated slightly right or left.
