I think this worked. This was for encoder backs, so you will need to change nMoterEncoder] to SensorValue() for OSE’s.
// function to run drive motors for specified distance in units defined by WHEEL_DIAM then stop the drive motors
// +dist = forward, -dist = reverse.
void driveDistance(int dist)
nMotorEncoder[drive_LF] = 0; // reset the ime values to 0
nMotorEncoder[drive_RF] = 0;
driveLastError = 0; // update driveLastError
driveTarget = fabs(dist/(WHEEL_DIAM*PI) * ENCODER_TICKS); // convert distance into encoder ticks. WHEEL_DIAM and ENCODER_TICKS set in globals
driveError = driveTarget - fabs(nMotorEncoder[drive_LF]); // initial error calculation
while (fabs(driveError) > DRIVE_ERROR_THRESH) // while more than DRIVE_ERROR_THRESH from target
driveError = driveTarget - fabs(nMotorEncoder[drive_LF]); // update error value
int drivePower = sgn(dist) * (drivePD_Kp * driveError) + (drivePD_Kd * (driveError - driveLastError)); // initial PD power calculation
drivePower = fabs(drivePower) > DRIVE_MAX_PWR ? sgn(drivePower) * DRIVE_MAX_PWR : drivePower; // limit power if calc is over max
// drive straight power modifier
int rDiff = fabs(nMotorEncoder[drive_LF]) - fabs(nMotorEncoder[drive_RF]); // check for right encoder difference
int rMod = sgn(rDiff)*drivePower*.1; // rMod = 10% drivePower in the direction of rDiff
set_drivePower( drivePower , drivePower + rMod );
driveLastError = driveError; // update driveLastError
wait1Msec(25);
set_drivePower( 0 , 0 ); // stop motors after target is reached
