Driver control backwards error
Hello there,
I’m new to code in C++ and Vexcode Pro. And I’m having a problem with code. I’m writing the user control part. I can write it to move forward but when I try to write it in backwards it gives error that “called object type ‘double’ is not a function or funcion pointer”. I’m not entirely sure with how to use axis aswell. I’m going to post the code below. Thanks already for support and answers.
double wSpeed = 1.0;
bool wDirec = 1;
if (wDirec)
rightDt.spin(directionType::fwd, console.Axis3.position()*wSpeed , percentUnits::pct);
leftDt.spin(directionType::fwd, console.Axis2.position()*wSpeed , percentUnits::pct);
else
rightDt.spin(directionType::fwd, console.Axis2.position()*wSpeed(-1) , percentUnits::pct);
leftDt.spin(directionType::fwd, console.Axis3.position()*wSpeed(-1) , percentUnits::pct);
You can not do this, not sure where you got that idea from. To negate wSpeed just put - in front.
-wSpeed
for reversing, instead of wSpeed(-1) do -wSpeed so that it would look like
leftDt.spin(fwd, Axis3.position * -wSpeed, pct);
trying to do wSpeed(-1) is unquestionably the part throwing the error, that simply isn’t a thing you can do.
I think I had already answered this, no need to post the same solution.
Oh shoot you’re right. Sorry!
says to self: WOW you are blind
