Driver Control Initiating with LCD Display?
I am wondering if I can start a user control code area with my lcd display as opposed to having to have a competition switch. Here is my code:
#pragma config(Sensor, dgtl1,  dgtl,           sensorLEDtoVCC)
#pragma config(Motor,  port2,           lfwAMotor,     tmotorVex393_MC29, openLoop)
#pragma config(Motor,  port3,           lfwBMotor,     tmotorVex393_MC29, openLoop)
#pragma config(Motor,  port4,           rfwAMotor,     tmotorVex393_MC29, openLoop)
#pragma config(Motor,  port5,           rfwBMotor,     tmotorVex393_MC29, openLoop)
#pragma config(Motor,  port6,           iMotor,        tmotorVex393_MC29, openLoop)
#pragma config(Motor,  port8,           lwMotor,       tmotorVex393_MC29, openLoop)
#pragma config(Motor,  port9,           rwMotor,       tmotorVex393_MC29, openLoop)
#pragma platform(VEX)
//Competition Control and Duration Settings
#pragma autonomousDuration(20)
#pragma userControlDuration(120)
const short leftButton = 1;
const short centerButton = 2;
const short rightButton = 4;
int count = 0;
//Wait for Press--------------------------------------------------
void waitForPress()
	while(nLCDButtons == 0){}
	wait1Msec(5);
//Wait for Release------------------------------------------------
void waitForRelease()
	while(nLCDButtons != 0){}
	wait1Msec(5);
#include "Vex_Competition_Includes.c"   //Main competition background code...do not modify!
void pre_auton()
	bLCDBacklight = true;
  SensorValue[dgtl1] = 1;
  //Declare count variable to keep track of our choice
	int count = 0;
	//------------- Beginning of User Interface Code ---------------
	//Clear LCD
	clearLCDLine(0);
	clearLCDLine(1);
	//Loop while center button is not pressed
	while(nLCDButtons != centerButton)
		//Switch case that allows the user to choose from 4 different options
		switch(count){
		case 0:
			//Display first choice
			displayLCDCenteredString(0, "Blue Tile");
			displayLCDCenteredString(1, "<		 Select		>");
			waitForPress();
			//Increment or decrement "count" based on button press
			if(nLCDButtons == leftButton)
				waitForRelease();
				count = 3;
			else if(nLCDButtons == rightButton)
				waitForRelease();
				count++;
			break;
		case 1:
			//Display second choice
			displayLCDCenteredString(0, "Red Tile");
			waitForPress();
				waitForRelease();
				count--;
				waitForRelease();
				count++;
			break;
		case 2:
			//Display third choice
			displayLCDCenteredString(0, "Test Blue");
			waitForPress();
				waitForRelease();
				count--;
				waitForRelease();
				count++;
			break;
		case 3:
			//Display fourth choice
			displayLCDCenteredString(0, "Autonomous 4");
			displayLCDCenteredString(1, "<		 Enter		>");
			waitForPress();
				waitForRelease();
				count--;
				waitForRelease();
				count = 0;
			break;
		default:
			count = 0;
			break;
	//------------- End of User Interface Code ---------------------
task autonomous()
	//------------- Beginning of Robot Movement Code ---------------
	//Clear LCD
	clearLCDLine(0);
	clearLCDLine(1);
	//Switch Case that actually runs the user choice
	switch(count){
	case 0:
		//If count = 0, run the code correspoinding with choice 1
		displayLCDCenteredString(0, "Autonomous 1");
		displayLCDCenteredString(1, "is running!");
		wait1Msec(2000);						// Robot waits for 2000 milliseconds
		// Move forward at full power for 3 seconds
startTask(usercontrol);
		break;
	case 1:
		//If count = 1, run the code correspoinding with choice 2
		displayLCDCenteredString(0, "Autonomous 2");
		// Move reverse at full power for 3 seconds
		break;
	case 2:
		//If count = 2, run the code correspoinding with choice 3
		displayLCDCenteredString(0, "Autonomous 3");
		//Turn right for 3 seconds
		break;
	case 3:
		//If count = 3, run the code correspoinding with choice 4
		//Turn left for 3 seconds
		break;
	default:
		displayLCDCenteredString(0, "No valid choice");
		displayLCDCenteredString(1, "was made!");
		break;
	//------------- End of Robot Movement Code -----------------------
	AutonomousCodePlaceholderForTesting();  // Remove this function call once you have "real" code.
task usercontrol()
	while (true)
			motor[lwMotor] = vexRT[Ch3] / 2;
    motor[rwMotor] = vexRT[Ch2] / 2;
    if(vexRT[Btn6U] == 1)
      motor[iMotor] = 127;
    else if(vexRT[Btn6D] == 1)
      motor[iMotor] = -127;
    else
      motor[iMotor] = 0;
    if(vexRT[Btn5U] == 1)
      motor[lfwAMotor] = 0;
      motor[rfwAMotor] = 0;
      motor[lfwBMotor] = 0;
      motor[rfwBMotor] = 0;
    else if(vexRT[Btn5U] == 1)
    else
      motor[lfwAMotor] = 83;
      motor[rfwAMotor] = 83;
      motor[lfwBMotor] = 83;
      motor[rfwBMotor] = 83;
	  UserControlCodePlaceholderForTesting(); // Remove this function call once you have "real" code.
