Helllo! How do I program my button so that when I click a button the drivetrain move forward 2 revolutions?
Like i want to run part of my auton during driver control by pressing a button.
Thank you
Thank you
VC, VCS, or PROS
20 char
I am using vex codee
why did u delete it when u could have edited ur comment
Here’s an excerpt from our code, note that this is all in a while loop to continually check if the button is bring pressed:
if (Controller1.ButtonL1.pressing()) {
ArmMotor.spin(forward, 100, pct);
Additionally, if you want to run the rest of your program simultaneously, you could try threading like so:
if (StackBumper.pressing() == true && StackerRunning == false) {
thread(stackfunction).detach();
Thank you solo much!
I didnt know how to do it😅
u c the little pencil on every one of ur comments
Can I make it so that the motors spins certain amount of degrees?
click or press the pencil then u can edit ur comment
Ohhhhhhh thank you!!
sure! Here’s an example of that.
RightMotor.rotateFor(cmdistance(10), rotationUnits::rev);
This is a blocking command as it stands, so if you want the rest of your code to run before this finishes you need to thread it through a function or add the boolean param
yeah forums r to help others. plus it helps all the clutter. cause i mean u think anyone would want to read ur thread if every other comment is a deleted one
i swear if someone flags this post. this is on topic cause he didnt know how to edit and im helping him
Thank you so much for your help
