So, we were using the vexcode v5 wizard to attach our drivetrain. (We made the base of the Stryker Hero bot as a starting point). It works fine, but we run into EITHER the forward-reverse being inverted OR the left-right being inverted. We are using the controller configuration where axis 3 is forward/back and axis 1 is left/right.
What can we do to fix this? The team really only has any experience using blocks for coding, btw.
We have tried the following:
Inverting drivetrain in the setup.
Switching motor cables
Driving backwards.
I think there’s a misunderstanding of what the issue is. I’ll try to bullet point it.
When going Straight, it behaves as it should:
When we push forward, the wheels spin forward.
When we pull backwards, the wheels spin backwards.
When turning, it behaves inverted.
Signaling right causes the right wheel to spin forwards and the left to spin backwards, making the robot turn left.
Signaling left causes the left wheel to spin forwards and the right to spin backwards, making the robot turn right.
Switching how the cables are connected only switches the problem; making the turning correct, but the forwards/backwards inverted.
Switching the drivetrain setup causes the same thing as switching the cables.
Switching the motor directions on the brain causes the same thing as switching cables or drivetrain setup.
I am seriously at a loss as to how the signals are getting mixed up.
Aaand, connecting a gyro sensor (which we’d not used on anything other than a TestBed in my PLTW class last year before) solved the issue. =D Aah, the sweet feeling of success.
