Need some help with my drivetrain PID. I have tried to get this to simply drive forward and turn during autonomous but that’s not happening right now. I don’t know what values to put for kD, kI, kP so I have tested with 0.1 for now.
Comments are from a video I found online relating to PID, added them to keep track of stuff for myself.
Thanks, all.
void pre_auton(void) {
vexcodeInit();
//Settings
double kP = 0.1;
double kI = 0.1;
double kD = 0.1;
double turnkP = 0.1;
double turnkI = 0.1;
double turnkD = 0.1;
//Autonomous Settings
int desiredValue = 0;
int desiredTurnValue = 0;
int error; //SensorValue - DesiredValue : position
int prevError = 0; //position 20 milliseconds ago
int derivative; //error - prevError : calculates speed
int totalError = 0; //totalError = totalError + error
int turnError; //SensorValue - DesiredValue : position
int turnPrevError = 0; //position 20 milliseconds ago
int turnDerivative; //error - prevError : calculates speed
int turnTotalError = 0; //totalError = totalError + error
bool resetDriveSensors = false;
//Variables modified for use
bool enableDrivePID = true;
int drivePID(){
while(enableDrivePID){
if(resetDriveSensors){
LeftMotor1.setPosition(0, degrees);
RightMotor1.setPosition(0, degrees);
//Get pos of 2 motors
int leftMotorPosition = LeftMotor1.position(degrees);
int rightMotorPosition = RightMotor1.position(degrees);
//Lateral Movement PID
//Get avg of 2 motors
int averagePosition = (leftMotorPosition + rightMotorPosition)/2;
//potential
error = averagePosition - desiredValue;
//Derivative
derivative = error - prevError;
//integral
totalError += error;
double lateralMotorPower = error * kP + derivative * kD + totalError * kI;
//Turning Movement PID
int turnDifference = (leftMotorPosition + rightMotorPosition)/2;
//potential
turnError = turnDifference - desiredTurnValue;
//Derivative
turnDerivative = turnError - turnPrevError;
//integral
turnTotalError += turnError;
double turnMotorPower = turnError * turnkP + turnDerivative * turnkD + turnTotalError * turnkI;
LeftMotor1.spin(forward, lateralMotorPower + turnMotorPower, voltageUnits::volt);
RightMotor1.spin(forward, lateralMotorPower - turnMotorPower, voltageUnits::volt);
turnPrevError = turnError;
prevError = error;
vex::task::sleep(20);
return 1;
/* Autonomous Task */
/* This task is used to control your robot during the autonomous phase of */
/* a VEX Competition. */
/* You must modify the code to add your own robot specific commands here. */
void autonomous(void) {
vex::task pidtest(drivePID);
resetDriveSensors = true;
desiredValue = 20;
desiredTurnValue = 30;
vex::task::sleep(1000);
