i just noticed this issue and i haven’t ever seen this before, Im not new to vex code so im confused.
# Library imports
from vex import *
import math
# Brain should be defined by default
brain=Brain()
mode = 3
log_directory = "/logs/"
"""drive Motors + Remote"""
motor_11 = Motor(Ports.PORT11, GearSetting.RATIO_6_1, True)
motor_12 = Motor(Ports.PORT12, GearSetting.RATIO_6_1, False)
motor_13 = Motor(Ports.PORT13, GearSetting.RATIO_6_1, False)
controller_1 = Controller(PRIMARY)
motor_18 = Motor(Ports.PORT18, GearSetting.RATIO_6_1, False)
motor_19 = Motor(Ports.PORT19, GearSetting.RATIO_6_1, True)
motor_20 = Motor(Ports.PORT20, GearSetting.RATIO_6_1, True)
right_side = MotorGroup(motor_11, motor_12, motor_13)
left_side = MotorGroup(motor_18, motor_19, motor_20)
compMode = True
#nerd
"""Extra Motors"""
motor_15 = Motor(Ports.PORT5, GearSetting.RATIO_6_1, False)
motor_16 = Motor(Ports.PORT6, GearSetting.RATIO_6_1, True)
intake = MotorGroup(motor_15, motor_16)
wings = DigitalOut(brain.three_wire_port.a)
climb_motor = Motor(Ports.PORT17, GearSetting.RATIO_36_1, False)
gyro = Inertial(Ports.PORT8)
"""init"""
intake.set_velocity(100, PERCENT)
right_side.set_velocity(100, PERCENT)
left_side.set_velocity(100, PERCENT)
climb_motor.set_velocity(100, PERCENT)
climb_motor.set_stopping(HOLD)
"""Wheel Base"""
wheelDiameterCM = 8.255
wheelTravel = 275
trackWidth = 370
wheelBase = 330
gearRatio = 1.667
drivetrain = SmartDrive(left_side, right_side, gyro, wheelTravel, trackWidth, wheelBase, MM, gearRatio)
class Team:
blue = 0
red = 1
skills = 2
# Begin project code
# Create callback functions for each controller button event
def onevent_controller_1buttonL1_pressed_0():
climb_motor.spin(FORWARD)
def onevent_controller_1buttonL1_released_0():
climb_motor.stop()
def onevent_controller_1buttonL2_pressed_0():
climb_motor.spin(REVERSE)
def onevent_controller_1buttonL2_released_0():
climb_motor.stop()
def forward(distance, speed):
# brain.screen.print("forward Start" + str(brain.timer.time(SECONDS)))
brain.screen.new_line
drivetrain.set_stopping(BRAKE)
drivetrain.set_drive_velocity(speed, PERCENT)
drivetrain.set_turn_velocity(speed, PERCENT)
drivetrain.drive_for(FORWARD, distance, MM)
drivetrain.stop()
# brain.screen.print("forward End" + str(brain.timer.time(SECONDS)))
brain.screen.new_line()
# drivetrain.set_stopping(COAST)
def turnToHeading(heading, speed):
# brain.screen.print("turn start" + str(brain.timer.time(SECONDS)))
# brain.screen.print("Velocity done"+ str(brain.timer.time(SECONDS)))
# Adjust the wait time as needed
drivetrain.turn_to_heading(heading, DEGREES)
drivetrain.stop()
# brain.screen.print("turn stop" + str(brain.timer.time(SECONDS)))
# Create Controller events - 15 msec delay to ensure events get registered
wait(10, MSEC)
# Configure Arm and Claw motor hold settings and velocity
def pre_autonomous():
global mode
gyro.calibrate()
# if brain.battery.capacity() <= 70 and compMode == True:
# brain.screen.set_font(FontType.PROP40)
# brain.screen.print("Change Battery")
if brain.sdcard.is_inserted():
brain.screen.clear_screen()
global sd
sd = True
mode = 3
brain.screen.draw_image_from_file("boot.png", 0, 0)
controller_1.screen.print("Carter Mode?")
global team
team = 1
"""Team 2 = Red, Team 3 = Blue, Team 4 = Skills"""
while mode not in (1, 2):
if controller_1.buttonA.pressing():
mode = 1
controller_1.screen.clear_line(1)
controller_1.screen.set_cursor(1,1)
controller_1.screen.print("you're just wrong")
if controller_1.buttonB.pressing():
mode = 2
controller_1.screen.print("Good choice")
wait(2, SECONDS)
while team not in (2, 3, 4):
team = 2
controller_1.screen.print("Red Team")
team = 3
controller_1.screen.print("Blue Team")
if controller_1.buttonX.pressing():
team = 3
controller_1.screen.print("Skills")
if not brain.sdcard.is_inserted():
brain.screen.print("No Sd card not logging")
# autonomous()
def autonomous():
# gyro.calibrate()
# pass
forward(2000, 100)
climb_motor.spin_for(FORWARD, 43, DEGREES)
turnToHeading(50, 50)
wings.set(True)
intake.spin(FORWARD)
forward(1450, 200)
turnToHeading(0, 50)
forward(850, 200)
turnToHeading(-90, 80)
wings.set(False)
forward(-600, 200)
forward(2200, 200)
forward(-500, 200)
intake.stop()
brain.screen.print("AUTO END AT" + str(brain.timer.time(SECONDS)))
def user_control():
# brain.screen.clear_screen()
controller_1.buttonR1.pressed(onevent_controller_1buttonL1_pressed_0)
controller_1.buttonR1.released(onevent_controller_1buttonL1_released_0)
controller_1.buttonR2.pressed(onevent_controller_1buttonL2_pressed_0)
controller_1.buttonR2.released(onevent_controller_1buttonL2_released_0)
# add 15ms delay to make sure events are registered correctly.
wait(15, MSEC)
while True:
if controller_1.buttonL2.pressing():
wings.set(True)
"""Deploy the wings"""
else:
wings.set(False)
if controller_1.buttonL1.pressing():
else:
intake.stop()
left_side.set_stopping(BRAKE)
right_side.set_stopping(BRAKE)
else:
left_side.set_stopping(COAST)
right_side.set_stopping(COAST)
if mode == 2:
"""Tank steering"""
right_side.spin(FORWARD)
left_side.spin(FORWARD)
right_side.set_velocity(controller_1.axis2.position(), PERCENT)
left_side.set_velocity(controller_1.axis3.position(), PERCENT)
elif mode == 1:
"""Single stick drive"""
carter = controller_1.axis4.position() / 2
carter_2 = controller_1.axis4.position() / 2
right_side.set_velocity((controller_1.axis3.position() - carter), PERCENT)
left_side.set_velocity((controller_1.axis3.position() + carter_2), PERCENT)
# create competition instance
comp = Competition(user_control, autonomous)
pre_autonomous()
# Main Controller loop to set motors to controller axis positions
