Thank you , got the answer,
Goal - A place where Stacks can be Placed. There are four (4) varieties of Goal in VIQRC Mix & Match:
● Square Goal - A segment of the Floor in a corner of the long side of the Field opposite from the
audience. Each Square Goal is bordered by the inside of the Field Perimeter and the inside edges of
the VEX IQ pieces connected to the Floor. Each Square Goal has a color, red or blue, determined by
its VEX IQ pieces and PET sheet. Each Square Goal can hold a maximum of one (1) Placed Stack.
● Floor Goal - A segment of the Floor in the center of the Field surrounding the Standoff Goal. The
Floor Goal is defined by the center, white-outlined portion of the PET sheet connected to the Floor
underneath the Standoff Goal, and includes that white line. The Floor Goal can hold a maximum of
four (4) Placed Stacks.
● Triangle Goal - A segment of the Floor in a corner of the long side of the Field closest to the
audience. Each Triangle Goal is bordered by the inside of the Field Perimeter and the inside of the
PVC pipe that spans the corner of the Field. Each Triangle Goal has a color, red or blue, determined
by its VEX IQ pieces, PVC pipe, and PET sheet. Each Triangle Goal can hold a maximum of three (3)
Placed Stacks.
● Standoff Goal - The orange plastic structure mounted to the center of the Field with IQ pins or
screws.
