I have been using EasyC 2.x on my Windows 7 Home Premium 64 Bit SP1 for a couple of months, and sometime in the last 3-4 weeks it has stopped working… I first noticed it today, and I am sure it was fine a few weeks ago…
When I click on the File Item of the Menu, I get this:
[ATTACH]5923[/ATTACH]
If I click on the Recent Projects, I get this:
[ATTACH]5926[/ATTACH]
I was using a slightly older version, but I updated to v2.9.3.8.
Easy C Pro ( 3.x ) is working fine, so is EasyC 1.x and EasyC 4.x.
Looking Back, I see there was a .NET Update on 13-APR-2012:
Security Update for Microsoft .NET Framework 3.5.1 on Windows 7 and
Windows Server 2008 R2 SP1 for x64-based Systems (KB2656373)
Installation date: ?4/?13/?2012 23:27
Installation status: Successful
Update type: Important
A security issue has been identified that could allow an authenticated
remote attacker to compromise your system and gain control over it. You
can help protect your system by installing this update from Microsoft. After
you install this update, you may have to restart your system.
More information:
http://go.microsoft.com/fwlink/?LinkID=237402
Help and Support:
http://support.microsoft.com
Security Update for Microsoft .NET Framework 4 on XP, Server 2003, Vista,
Windows 7, Server 2008, Server 2008 R2 for x64 (KB2656368)
Installation date: ?4/?13/?2012 23:30
More information:
http://go.microsoft.com/fwlink/?LinkID=237397
Help and Support:
and some more on 11-MAY-2012:
Windows Server 2008 R2 SP1 for x64-based Systems (KB2656411)
Installation date: ?5/?11/?2012 00:54
A security issue has been identified that could allow an attacker to break or
bypass a security feature in the affected software. You can help protect
your system by installing this update from Microsoft. After you install this
More information:
http://go.microsoft.com/fwlink/?LinkID=237430
Help and Support:
Windows Server 2008 R2 SP1 for x64-based Systems (KB2604115)
A security issue has been identified that could allow an unauthenticated
More information:
http://go.microsoft.com/fwlink/?LinkID=226971
Help and Support:
Windows 7, Server 2008, Server 2008 R2 for x64 (KB2604121)
Installation date: ?5/?11/?2012 00:58
More information:
http://go.microsoft.com/fwlink/?LinkID=226972
Help and Support:
Windows 7, Server 2008, Server 2008 R2 for x64 (KB2656405)
Installation date: ?5/?11/?2012 01:00
More information:
http://go.microsoft.com/fwlink/?LinkID=237425
Help and Support:
EasyC 2.9.3.8 is still crashing on the “File” Menu, as detailed above…
I’d recommending reinstalling easyC V2. easyC Pro and V2 are built from the same engine so if Pro works then so should V2.
If you want to be 100% sure its a clean install, uninstall easyC V2, goto “Program Files (x86)\Intelitek” and delete “easyC V2 for Vex”, and goto “%appdat%\Inteliteik” and delete “easyC V2 for Vex”.
I have noticed that… If EasyC 2.x is running, you can not start EasyC Pro ( 3.x )…
About that…
I did have version 2.9.3.2 Installed when I noticed that this “crashing” started. So I updated to 2.9.3.8, which is having the same issue.
As a minor irritation on the Installers part, the “newer version”, says that an “older version” is Installed and must be removed. Which it will, but then Exits… I have to then Run the Installer, again, at which point it doesn’t remember where the recently installed version was installed, and assumes the default…
I will remove the current version, and remove any “cruft”, then re-install…
BTW, if EasyC 2.x is running, attempting to start EasyC 3.x results in a Dialog Box of “Application Already Running”. If EasyC 3.x is running, attempting to start EasyC 2.x results in no notification at all… If this is any indication of misbehavior…
