I’ve been writing code in ROBOTC for a while now, and I was asked to write a program for a team in easyC. I was having little issue writing the program, but I ran across a weird peculiarity. I was programming the joystick so that every time you press one of the buttons, it would change a digital output (pneumatics). Normally, you could just use Joystick Digital to Digital Output, but it needed to be every time you push the button, it would change to the other value (0 to 1 and vice versa). My way of writing this in ROBOTC is as follows:
This code works fine, I could detect whether button has been pressed and if it is currently pressed. The AutoClamp() detects what the clamp currently is and changes it accordingly.
Now, the problem arises when I write the same code in easyC. I of course change the syntax so we call the button before querying, falses to 0s, trues to 1s etc., etc. The issue is that when the button is pressed, the pneumatics start rapidly switching back and forth. It is as if the robot doesn’t change the the ClampPressed value.
My question is this: how do you detect when the a joystick button has been pressed or how do you achieve the same thing I’m trying to do here?
The way I do it is I have a Controller struct that holds the previous state of all the button presses and updates during each iteration of the while(true) loop.
So if you want to detect a button that just went down, you would do something like:
Controller Joystick;
//Some other code
if(Joystick.Buttons_Down[GetJoystickIndexFromButton(Btn7R)])
//do stuff
Where Joystick has the fields Buttons_Down, Buttons_Up, and Buttons_Last. Buttons_Down for a button is true when vexRT = true but Buttons_Last = false. Buttons_Up is the opposite. The struct’s fields are updated each loop.
It’s useful for toggles for single buttons as well as for double button toggles, but it’s a bit more complex for double toggles.
Any chance I could get a full copy of that RobotC file? I want to achieve that effect, but AutoClamp() is an unrecognized procedure and I’m not sure if I’m missing something…
Yep, AutoClamp() automatically switches whatever servo/pneumatics you have and uses the boolean ClampCurrent as a watchdog to know where the clamp currently is.
I also wrote a little function where you can set the clamp yourself. The only difference from any other function is that it changes ClampCurrent, so if you call AutoClamp() after messing with the current position of the clamp, it will go to the actual opposite position.
You should also initialize ClampCurrent outside those two functions (so it acts as a global). Also, false is clamp off and true is clamp on.
bool ClampCurrent = false;
I initialized ClampCurrent as false because a) you could run into some potential issues with you running AutoClamp with no value (should never happen) and b) I set the clamp using two standard motor] during the startup sequence of my code.
Thank you very much for replying, but where would I connect this all to a button on the joystick? And where you wrote motor I should change to the pneumatic sensor port and change the value to 1 and 0 right? Sorry for my ignorance, I just started using RobotC and its hard to get used to from EasyC. And thanks again for any help.
EDIT:
If you happen to have the time, could you go over this? I used your code but just changed the motor to pneumatics and the values to 1s and 0s…Im not sure if I have the variable types correct (or in the right place) and same with the function. Again, any help is much appreciated
DOUBLEEDIT:
I finally got access to the robot to test the program and…IT WORKS! Thank you so much edjubuh, I would have never gotten that to work by myself. You saved myself and my team a whole bunch of time and headaches. Really, that had stumped both myself and our real programmer since the beginning of the year. Thank you again
Hopefully we will see each other at Worlds this year, however if we don’t, we all wish you the best of luck. PneumaticTest.c (3.39 KB)
