I’m having trouble with VexNet. What can I do to fix it?
Start Here: http://content.vexrobotics.com/docs/VEXnet_Cortex_UserGuide_081811.pdf
What is the latest version of easyC?
See my signature below.
Where can I download the latest version of easyC V2
- You can download easyC V2-PIC from http://www.intelitekdownloads.com/easyCV2
Where can I download the latest version of easyC PRO
- You can download easyC PRO-PIC from http://www.intelitekdownloads.com/easyCPRO
What version of easyC for PIC supports VexNet?
easyC V2 - 2.9.3.0 and Higher
easyC PRO - 3.1.3.0 and Higher
What do I need to Run/Install easyC?
Windows XP SP3/Vista/Win 7
PIII-1000MHz+, 512MB
200MB Hard Disk Space
Administrator Access for installation and drivers
** I get Error 1000 unlocking easyC **
The key you entered into easyC doesn’t match any keys in the database.
Check and make sure that the key you entered is correct and if it is please
contact [email protected].
** I get Error 1007 unlocking easyC **
easyC thinks you have registered all of your available copies of easyC. If you
haven’t please contact [
Check an make sure the driver is installed for your programming cable. In the device manager goto Ports Serial / LPT and look for Vex CDC Driver (COM X) or Prolific USB-To-Serial (COM X)** I get an error opening the serial port or getting vex system info.**]([email protected].)
