easyc zip files
How do you open zip files in easyc pro? Whenever I try and open a program someone gave me on the forums it sais that it can’t open it.
Zip is just a special type of folder that they use for ease of use (archive), to open the program in easyc you need to extract it as the contents are inside it. I use winrar to extract these files but you could also use winzip or something similar.
As far as I know, you cannot directly open zipped files using any version of EasyC. First you need to run an appropriate compression program (or unzip program) to extract the compressed files to a desired directory.
PKWARE or 7-zip are free unzip programs that will do a good job. You should then be able to open them with a compatible version of EasyC.
Windows Explorer can handle zipped folders as well. look for the Extract button at the top,
