EDR Clawbot: first time builder question
New teacher here. We are building our first clawbots (the older ones, not V5)
Is there a way to restore the default programming? I keep reading that they have a default programming. One of the robots have this programming, but the others all have their own thing going on. Is there a way to restore the default programming on all the robots, or will I manually have to reprogram all of them individually?
Thanks!
You should be able to restore the default drive program with the VEXNet Firmware Upgrade Utility (download link all the way at the bottom of this page, under “Legacy Firmware”).
Be sure the option “default code” is set to “on”.
Description of the default code starting on page 6 of this PDF.
