Are edu-bot motors compatible with the VEX brain? If so i just found 4-5 in my FRC team’s ‘robot room’… If they’re not i could do a driver and manipulator setup using my VEX stuf w/ brain and the edu bot motors and stuff on its brain!
I’ve been up the same road, moving from edubot to vex. Vex stuff has different connectors( opposite gender from edubot). You’ll have to make a special gender changing cable or change the connectors.
Code is more or less compatible though.
~ Christopher
