Are there any example of how to use the EEprom in C?
**Here is an example from one of our libriary files written in assembly:
;* FILE NAME: Asm_lib.asm
;* DESCRIPTION:
;* This file contains routines needed by the serial driver.
#include p18cxxx.inc
GLOBAL GetEEData,ReadEE,WriteEE
GLOBAL gVar1
ASM_VAR UDATA_ACS 0x0 ; Force address to zero, since MATH_DATA
gVar1 RES .20
FSR0L_TEMP RES 1 ; normally gets this address
FSR0H_TEMP RES 1
gByteCnt RES 1
grtnByte RES 1
ASM_LIB CODE
;* FUNCTION NAME: ReadEE
;* PURPOSE: read a byte from a specified EEprom location
ReadEE ; (uword8 addr, uword8 gByteCnt, uword8 *bufr)
MOVFF FSR0H,FSR0H_TEMP
MOVFF FSR0L,FSR0L_TEMP
MOVLW 0xff ;two's complement representation of -1
MOVFF PLUSW1,EEADR ;get location from stack
MOVLW 0xfe ;two's complement representation of -2
MOVFF PLUSW1,gByteCnt ;get count from stack
MOVLW 0xfd ;two's complement representation of -3
MOVFF PLUSW1,FSR0H ;get upper address from stack
MOVLW 0xfc ;two's complement representation of -4
MOVFF PLUSW1,FSR0L ;get lower address from stack
clrf EEADRH
ReadEE_loop
clrf EECON1
bsf EECON1, RD ; Read the data
movff EEDATA, POSTINC0
infsnz EEADR, F ; Adjust EEDATA pointer
incf EEADRH, F
decfsz gByteCnt,F
bra ReadEE_loop ; Not finished then repeat
MOVFF FSR0H_TEMP,FSR0H
MOVFF FSR0L_TEMP,FSR0L
return
;* FUNCTION NAME: GetEEData
;* PURPOSE: returns a byte from a specified EEprom location
GetEEData ; (uword8 addr)
MOVFF PLUSW1,EEADR
clrf EEADRH
clrf EECON1
movff EEDATA, grtnByte
movf grtnByte,w
return
;* FUNCTION NAME: WriteEE
;* PURPOSE: write a byte to a specified EEprom location
WriteEE ;(uword8 addr, uword8 gByteCnt, uword8 *bufr)
clrf EEADRH
WriteEE_loop
movff POSTINC0, EEDATA
movlw b'00000100' ; Setup for EEData
movwf EECON1
rcall StartWrite
WriteWait
btfsc EECON1, WR ; Write and wait
bra WriteWait
incf EEADRH, F
decfsz gByteCnt,F
bra WriteEE_loop ; Not finished then repeat
return
;* FUNCTION NAME: StartWrite
;* PURPOSE: Unlock and start the write or erase sequence.
StartWrite
clrwdt
movlw 0x55 ; Unlock
movwf EECON2
movlw 0xAA
movwf EECON2
bsf EECON1, WR ; Start the write
nop
return
END
