Probably allot of errors. Working through the code to print to the V5 Brain, Terminal, and *.dat file on computer. However I’m not understanding the problem with the returned array memory address…help asked for.
/* Module: main.cpp */
/* Author: LoJac10 */
/* Created: Wed Sep 25 2019 */
/* Description: Moving Forward (inches) */
/* This program drives the robot forward for 6 inches. Additionally this */
/* program will print smartmotor encoder info to brain screen and a */
/* *.dat file on your computer. */
// Robot Configuration:
// [Name] [Type] [Port(s)]
// Drivetrain drivetrain 1, 2, 19, 20
// lfMotor smartmotor 1
// lbMotor smartmotor 2
// rfMotor smartmotor 19
// rbMotor smartmotor 20
#include "vex.h"
using namespace vex;
void resetDriveEncoders()
lbMotor.setPosition(0, rotationUnits::raw);
lfMotor.setPosition(0, rotationUnits::raw);
rbMotor.setPosition(0, rotationUnits::raw);
rfMotor.setPosition(0, rotationUnits::raw);
double *driveOffsetCal()
// ** side diff **
double leftsideDiff = lfMotor.position(rotationUnits::raw) - lbMotor.position(rotationUnits::raw);
double rightsideDiff = rfMotor.position(rotationUnits::raw) - rbMotor.position(rotationUnits::raw);
// ** cross diff **
double frontcrossDiff = lfMotor.position(rotationUnits::raw) - rfMotor.position(rotationUnits::raw);
double backcrossDiff = lbMotor.position(rotationUnits::raw) - rbMotor.position(rotationUnits::raw);
double arr[4] = {leftsideDiff, rightsideDiff, frontcrossDiff, backcrossDiff};
return arr;
int driveOffsetDisplay( )
// pointer to returned array from driveOffsetCal
double *ptr;
// open 'output.dat' file to write to on computer
std::ofstream output;
output.open("output.dat");
// pointer to variable
ptr = driveOffsetCal();
// clear screen to display encoder info
Brain.Screen.clearScreen();
// display some useful info on screen
Brain.Screen.setCursor(2,1);
// left-side encoder difference
Brain.Screen.print( " LSdiff: %4.0f", ptr[0] );
Brain.Screen.newLine();
std::cout << "LSdiff: " << ptr[0] << std::endl;
// right-side encoder difference
Brain.Screen.print( " RSdiff: %4.0f", ptr[1] );
std::cout << "RSdiff: " << ptr[1] << std::endl;
// front motors encoder difference
Brain.Screen.print( " FCdiff: %4.0f", ptr[2] );
std::cout << "FCdiff: " << ptr[2] << std::endl;
// back motors encoder difference
Brain.Screen.print( " BCdiff: %4.0f", ptr[3] ); // print to brain
std::cout << "BCdiff: " << ptr[3] << std::endl; // print to terminal
// writes info to 'output.dat'
output << "LeftSidediff: " << ptr[0] << std::endl;
output << "RightSidediff: " << ptr[1] << std::endl;
output << "FrontCrossdiff: " << ptr[2] << std::endl;
output << "BackCrossdiff: " << ptr[3] << std::endl;
// close 'output.dat' file
output.close();
// exit code
return 0;
// MAIN
int main() {
vexcodeInit();
resetDriveEncoders();
driveOffsetDisplay( );
Drivetrain.driveFor(forward, 6, inches);
return 0;
A local variable created inside a function exists on the stack (the stack being an area of memory). Once the function returns the variable goes out of scope, that area of memory may be used by other code. Best to pass a pointer to an array and copy results into it.
This assigns result of calling driveOffsetDisplay_Brain to display.pBrain, I suspect you wanted address of driveOffsetDisplay_Brain.
display.pBrain;
?? That’s just a variable, you don’t do anything with it.
If you wanted to call a function, look into making pBrain a pointer.
but it seems way over complicated.
