I have an issue with my code. I’m using VEXText this year, and I put my drivetrain & configuration in the code. I configured it too, but whenever I compile it, I get this error.
[error]: make process closed with exit code : 2
I tried moving the configuration to the two different robot configuration files (.h and .cpp), but it’s still not working. Any tips?
That isn’t the error, that just says it has an error.
Send us your code and/or the rest of the compile log
it’s fine; I got it figured out :))
If you could post how you fixed it that would help future users. I usually just do a restart of the program to fix a make error.
Well I used the simplified configuration in the top right corner. I’m not using the text one anymore.
