Error compiling code on blocks using Chromebook
so i got a computer for programming but i cant get the code to compile. it works with a wireless wifi but not with wired. please help thanks.
With Chromebooks, sometimes the connections are registered as “too slow” and so it doesn’t think it can download. Two ways to fix this are one using as USB-C to micro USB instead of USB-A to micro USB, or two, using an older desktop or laptop that will recognize the connection.
Ok, I’ll try that thanks.
The wireless wifi is probably not blocking access to the cloud compiler, but the wired connection is. You’ll need to contact your system administrator / IT department and point them to this resource:
so i have tried the wireless wifi and it still wont work
did you try a usb-c to micro usb or another older desktop/laptop?
