Error.. controller must be updated to latest version
Connected to VEX OS is showing everything up to date and then when I unplug … the brain goes directly to flashing error message stating that controller must be updated.
Here is the most current system report from the brain – it shows that controller doesn’t need updating
VEX IQ System Report*
System Version: 2.2.0
System ID: 98810
Hardware Version: 1
— Start Connected Devices —
Sensor Type: IQ_MOTOR Mode: RAM NeedUpdate: False V: 8.b0 BootV: 4
Sensor Type: IQ_EMPTY Mode: BOOT NeedUpdate: False V: 0.b0 BootV: 0
Sensor Type: IQ_LED Mode: RAM NeedUpdate: False V: 2.b0 BootV: 4
Brain Radio: Type: Radio900 Minor: 0 Beta: 0 NeedUpdate: False
Controller Radio: Type: Radio900 Minor: 0 Beta: 0 NeedUpdate: False
Controller: Minor: 9 Beta: 0 NeedUpdate: False
Total Devices to update: 0
— End Connected Devices —
I have done a hard reset on the brain and done a force update on the brain with the controller attached and still get the same results… anyone got a fix?
I am having the EXACT same issue. Changed batteries, changed wires, tried various fixes. Same result
@Jamessalvant @Misti_Kemmer ,
This issue has not shown up in any of our testing. We are having trouble trying to reproduce.
The system report looks correct, from what I can see.
Is this happening on more than one brain?
Thanks
I am having the same problem on 2 robots. I have updated everything and restarted everything.
@erinrayj Can you post a system report from the VEXos utility?
Do you have more than 2 IQ systems?
If so are the other working correctly?
Thanks
Had another one do it this morning… Here is what I can figure out… the brain was being programmed on a chromebook and it gave message that brain needed updating. I plugged it into a windows machine to do update and it showed an updated needed for the brain. The VEXos utility completed the update and then when the brain restarted it instantly went into error… controller must be updated to latest version. It was stuck on that screen and would blink and go back to the error.
There was not a remote attached during the update and the project that we are doing is an autonomous project not requiring a remote.
I think what is happening is that the brain is retaining some old data from a previous controller that was hooked up to the brain and when the brain turns on and starts to search for a controller it triggers the error… even though there is not a controller paired to the brain.
Here is the error log
System ID: 22439
Hardware Version: 1
Sensor Type: IQ_RGB Mode: RAM NeedUpdate: False V: 5.b0 BootV: 4
Controller Radio: Type: RadioUnknown Minor: 0 Beta: 0 NeedUpdate: False
Controller: Minor: 0 Beta: 0 NeedUpdate: False
— Start SysStatus —
JoyMajorVersion: 1 : 1
JoyMinorVersion: 6 : 110
SysStatus: 81 : 10000001
SysStatus4: 0 : 0
SysStatus3: 0 : 0
lostlinkCntr: 8 : 1000
DeviceStatusMask1: 0 : 0
DeviceStatusMask2: 0 : 0
DeviceUpdateTotal: 0 : 0
SysStatus2: 40 : 1000000
radioId: 12 : 10010
PacketNo: B : 1011
SysStatus5: 0 : 0
ProgramState: 1 : 1
NumSRConnections: 0 : 0
SR_JS_RSSI: 0 : 0
SRBufferFill: 0 : 0
SRBufferFill_MAX: 4F : 1001111
SRBufferFill_RadioMAX: 0 : 0
— End SysStatus —
— Query Info —
BrainMajorVersion: 2 : 10
BrainMinorVersion: 5 : 101
DeviceUpateTotal: 0 : 0
DeviceUpdateType: 00000000 : 0
BootMajorVersion: 0 : 0
BootMinorVersion: 0 : 0
BrainStatus: 0 : 0
— End Query Info —![vexOS|375x500]
To fix I took the battery out and connected a controller to the brain and then reconnected the brain with controller attached to the VEXos and performed a force update (right click on brain to bring up menu in VEXos) and that solved the issue and the brain is working again with no errors.
I am having the exact same problem. The suggested repair in this strand doesn’t work. I’ve had at least three VEX IQ (first generation) bots with this same problem. Anybody got a sure fire fix???
Had another one do this… gen1… force update didn’t work on this one… anyone have method to fix
any luck getting it solved… just had another one do it today… working fine and then they needed to change controllers
after sitting over the weekend the brain now starts up just fine ???
Can anyone explain what is happening with these brains.
Here’s the answer I got from a FB post (I didn’t try it yet):
“I had that issue and finally got it to work. It requires un-installing and re-installing Vexos. Then plug the brain in first, then tether the remote while plugged into Vexos. It should force the brain into a system reset/recovery & restore it back to the first version for the brain. Once that is done, unplug, turn off brain and remove and close Vexos. Pull Vexos back up, turn brain back on, tether remote, and it should show the brain needs updated. That should fix it. It was only when the brain was forced into recovery that it would communicate with the remote. Had several /brain/remote combos that did this to me.”
