Howdy, I’m writing some code in the comp format and i’ve got a bug that I can’t seem to resolve. Ill attach the code below. I know the error is telling me that i’ve defined several variables in more than one place, but i’ve looked over my code several times and I simply do not see any instance of me defining the variables anywhere but under DriveFunctions.
This is the error message:
[info]: Saving Project …
[info]: Project saved!
windows build for platform vexv5
“LINK build/POWERHUBSKILLS.elf”
build/src/GeneralFunctions.o: In function `ScreenReadOut()':
GeneralFunctions.cpp:(.text._Z13ScreenReadOutv+0x0): multiple definition of `ScreenReadOut()’
build/src/main.o:main.cpp:(.text._Z13ScreenReadOutv+0x0): first defined here
build/src/DriveFunctions.o:(.bss.FB+0x0): multiple definition of `FB’
build/src/main.o:(.bss.FB+0x0): first defined here
build/src/DriveFunctions.o:(.bss.PowerH+0x0): multiple definition of `PowerH’
build/src/main.o:(.bss.PowerH+0x0): first defined here
build/src/DriveFunctions.o:(.bss.RL+0x0): multiple definition of `RL’
build/src/main.o:(.bss.RL+0x0): first defined here
build/src/DriveFunctions.o: In function `DriveTrain()':
DriveFunctions.cpp:(.text._Z10DriveTrainv+0x0): multiple definition of `DriveTrain()’
build/src/main.o:main.cpp:(.text._Z10DriveTrainv+0x0): first defined here
build/src/DriveFunctions.o: In function `catty()':
DriveFunctions.cpp:(.text._Z5cattyv+0x0): multiple definition of `catty()’
build/src/main.o:main.cpp:(.text._Z5cattyv+0x0): first defined here
build/src/DriveFunctions.o: In function `Intake()':
DriveFunctions.cpp:(.text._Z6Intakev+0x0): multiple definition of `Intake()’
build/src/main.o:main.cpp:(.text._Z6Intakev+0x0): first defined here
build/src/DriveFunctions.o:(.bss.fire+0x0): multiple definition of `fire’
build/src/main.o:(.bss.fire+0x0): first defined here
build/src/DriveFunctions.o:(.data.fire_speed+0x0): multiple definition of `fire_speed’
build/src/main.o:(.data.fire_speed+0x0): first defined here
build/src/DriveFunctions.o:(.bss.mode+0x0): multiple definition of `mode’
build/src/main.o:(.bss.mode+0x0): first defined here
build/src/DriveFunctions.o:(.bss.toggle_I+0x0): multiple definition of `toggle_I’
build/src/main.o:(.bss.toggle_I+0x0): first defined here
build/src/DriveFunctions.o:(.bss.toggle_S+0x0): multiple definition of `toggle_S’
build/src/main.o:(.bss.toggle_S+0x0): first defined here
build/src/DriveFunctions.o:(.bss.toggle_W+0x0): multiple definition of `toggle_W’
build/src/main.o:(.bss.toggle_W+0x0): first defined here
make: *** [vex/mkrules.mk:18: build/POWERHUBSKILLS.elf] Error 1
[error]: make process closed with exit code : 2
And this is my code:
(main.cpp)
/* Module: main.cpp */
/* Author: VEX */
/* Created: Thu Sep 26 2019 */
/* Description: Competition Template */
// Robot Configuration:
// [Name] [Type] [Port(s)]
// MotorPR motor 1
// MotorPL motor 11
// MotorBR motor 2
// MotorBL motor 12
// MotorTR motor 3
// MotorTL motor 13
// Controller1 controller
// OpticalS optical 21
// Inertial inertial 20
#include "iostream"
#include "vex.h"
#include "DriveFunctions.cpp"
#include "GeneralFunctions.cpp"
#include "AutonFunctions.cpp"
using namespace std;
using namespace vex;
competition Competition;
/* Pre-Autonomous Functions */
/* You may want to perform some actions before the competition starts. */
/* Do them in the following function. You must return from this function */
/* or the autonomous and usercontrol tasks will not be started. This */
/* function is only called once after the V5 has been powered on and */
/* not every time that the robot is disabled. */
void pre_auton(void) {
vexcodeInit();
/* Autonomous Task */
/* This task is used to control your robot during the autonomous phase of */
/* a VEX Competition. */
/* You must modify the code to add your own robot specific commands here. */
void autonomous(void) {
// Insert autonomous user code here.
/* User Control Task */
/* This task is used to control your robot during the user control phase of */
void usercontrol(void) {
while (1) {
// This is the main execution loop for the user control program.
// Each time through the loop your program should update motor + servo
// values based on feedback from the joysticks.
task Task3 = task(catty);
task Task1 = task(ScreenReadOut);
task Task2 = task(DriveTrain);
task Task4 = task(Intake);
// Insert user code here. This is where you use the joystick values to
// update your motors, etc.
// prevent wasted resources.
// Main will set up the competition functions and callbacks.
int main() {
// Set up callbacks for autonomous and driver control periods.
// Run the pre-autonomous function.
pre_auton();
// Prevent main from exiting with an infinite loop.
while (true) {
wait(100, msec);
(DriveFunctions)
#include "vex.h"
int mode = 0;
int fire = 0;
int fire_speed=100;
int toggle_W =0;
int toggle_S =0;
int toggle_I =0;
int FB=0;
int RL=0;
motor_group PowerH= motor_group(MotorPR,MotorPL);
int DriveTrain(){
while(true){
while(mode==0){
int ABR = (abs(Controller1.Axis1.position())+abs(Controller1.Axis2.position()));
int ABL= (abs(Controller1.Axis3.position())+abs(Controller1.Axis4.position()));
int rev=0;
if(ABL>ABR){
FB = Controller1.Axis3.position();
RL = Controller1.Axis4.position();
rev=1;
else{
FB = -(Controller1.Axis2.position());
RL = -(Controller1.Axis1.position());
rev=-1;
if((Controller1.Axis3.position())-(Controller1.Axis4.position())<1&&(Controller1.Axis3.position())+(Controller1.Axis4.position())<1||
(Controller1.Axis3.position())-(Controller1.Axis4.position())>1&&(Controller1.Axis3.position())+(Controller1.Axis4.position())>1){
MotorBR.spin(fwd,FB-(RL*rev),pct);
MotorTR.spin(fwd,FB-(RL*rev),pct);
MotorBL.spin(fwd,FB+(RL*rev),pct);
MotorTL.spin(fwd,FB+(RL*rev),pct);
else{
MotorBR.spin(fwd,(FB-(RL*rev))/1.7,pct);
MotorTR.spin(fwd,(FB-(RL*rev))/1.7,pct);
MotorBL.spin(fwd,(FB+(RL*rev))/1.7,pct);
MotorTL.spin(fwd,(FB+(RL*rev))/1.7,pct);
//checks to see if you are trying to change mode.
if (Controller1.ButtonA.pressing()) {
mode = 1;
wait(300,msec);
while(mode==1){
//tank
MotorTR.spin(fwd,(Controller1.Axis2.position()),pct);
MotorBR.spin(fwd,(Controller1.Axis2.position()),pct);
MotorTL.spin(fwd,(Controller1.Axis3.position()),pct);
MotorBL.spin(fwd,(Controller1.Axis3.position()),pct);
mode = 0;
wait(300,msec);
return 0;
//Task for cattipult that will be run repeatedly durring driver controll
int catty() {
while(true){
if(Controller1.ButtonR2.pressing()){
if(toggle_S ==1){
toggle_S=0;
PowerH.stop();
wait(300,msec);
else if(toggle_S==0){
toggle_S=1;
PowerH.spin(fwd,fire_speed,pct);
wait(300,msec);
if(Controller1.ButtonUp.pressing()){
fire_speed= fire_speed-10;
if(Controller1.ButtonDown.pressing()){
fire_speed= fire_speed+10;
wait(250,msec);
return 0;
//Intake code for driver controll
int Intake(){
while(true){
while(Controller1.ButtonL1.pressing()){
PowerH.spin(fwd,100,pct);
wait(300,msec);
while(Controller1.ButtonL2.pressing()){
PowerH.spin(reverse,100,pct);
wait(300,msec);
PowerH.stop();
wait(300,msec);
return 0;
Please help!
