I have this error in my code and I can’t fix it. I’ve checked to see if everything is paired, and they are.
[error]: Missing build file in the project folder: makefile
VexCode saves its projects in folders, and among those things, those folders contain the build files in addition to your code. You should check to see if your code is in the folder with all those other files. I’ve seen this error before when I tried to just open the [project name].v5code file on its own.
