Hello, I am making this post to see if anybody can help me with an error while compiling my code. I’ve already troubleshooted the cord, computer, and brain, so it has to be something wrong inside of my VEXcode Pro V5. I am fairly new to coding, but most of this is transferred directly from blocks, and there are no console errors, warnings, or info. Also, sometimes when trying to upload the code, there’s a message that pops up with a warning sign that says, “Building, Error”
I have the output, code, and terminal in the replies.
The code’s tasks are to
- Set all motor parameters to 100% (Taken from Blocks code)
- Name certain motors
- Bind multiple motors to one button (Taken from Blocks code)
Code:
/* Module: main.cpp */
/* Author: C:\Users\lrhoda0178 */
/* Created: Sat Jan 23 2021 */
/* Description: V5 project */
// Robot Configuration:
// [Name] [Type] [Port(s)]
// Mid_Intake motor 7
// Low_Intake_R motor 4
// Low_Intake_L motor 5
// High_Intake motor 6
// Elevator motor 8
// Controller1 controller
// Drivetrain drivetrain 2, 1
#include "vex.h"
#include "robot-config.h"
using namespace vex;
int main() {
vexcodeInit();
// Include the V5 Library
// Allows for easier use of the VEX Library
float myVariable;
event message1 = event();
event why_am_i_here_______ = event();
//AUTONOMOUS CODE PATH
void autonomous(void){;
Low_Intake_L.rotateFor(vex::directionType::fwd, 2000 ,vex::rotationUnits::deg);
// "when started" hat block
int whenStarted1() {
// Set all motors to max speed
Mid_Intake.setVelocity(100.0, percent);
Low_Intake_R.setVelocity(100.0, percent);
Low_Intake_L.setVelocity(100.0, percent);
High_Intake.setVelocity(100.0, percent);
Elevator.setVelocity(100.0, percent);
Drivetrain.setDriveVelocity(100.0, percent);
Drivetrain.setTurnVelocity(100.0, percent);
return 0;
//Spin intakes and elevator when A or B are pressed
int whenStarted2() {
while (true) {
if (Controller1.ButtonA.pressing()) {
Elevator.spin(forward);
High_Intake.spin(forward);
Mid_Intake.spin(forward);
else {
if (Controller1.ButtonB.pressing()) {
Elevator.spin(reverse);
High_Intake.spin(reverse);
Mid_Intake.spin(reverse);
else {
Elevator.stop();
High_Intake.stop();
Mid_Intake.stop();
wait(5, msec);
return 0;
//Spin lower left and right intakes when r1 or r2 are pressed
int whenStarted3() {
while (true) {
if (Controller1.ButtonR1.pressing()) {
Low_Intake_R.spin(forward);
Low_Intake_L.spin(forward);
else {
if (Controller1.ButtonR2.pressing()) {
Low_Intake_R.spin(reverse);
Low_Intake_L.spin(reverse);
else {
Low_Intake_R.stop();
Low_Intake_L.stop();
wait(5, msec);
return 0;
using signature = vision::signature;
using code = vision::code;
// A global instance of brain used for printing to the V5 Brain screen
brain Brain;
// VEXcode device constructors
motor Mid_Intake = motor(PORT7, ratio18_1, false);
motor Low_Intake_R = motor(PORT5, ratio18_1, false);
motor Low_Intake_L = motor(PORT4, ratio18_1, true);
motor High_Intake = motor(PORT6, ratio18_1, true);
motor Elevator = motor(PORT8, ratio18_1, false);
controller Controller1 = controller(primary);
motor LeftDriveSmart = motor(PORT2, ratio18_1, true);
motor RightDriveSmart = motor(PORT1, ratio18_1, false);
drivetrain Drivetrain = drivetrain(LeftDriveSmart, RightDriveSmart, 319.19, 295, 40, mm, 1);
// VEXcode generated functions
// define variable for remote controller enable/disable
bool RemoteControlCodeEnabled = true;
// define variables used for controlling motors based on controller inputs
bool Controller1RightShoulderControlMotorsStopped = true;
bool Controller1UpDownButtonsControlMotorsStopped = true;
bool Controller1XBButtonsControlMotorsStopped = true;
// define a task that will handle monitoring inputs from Controller1
int rc_auto_loop_function_Controller1() {
// process the controller input every 20 milliseconds
// update the motors based on the input values
while(true) {
if(RemoteControlCodeEnabled) {
// check the ButtonR1/ButtonR2 status to control Elevator
Controller1RightShoulderControlMotorsStopped = false;
} else if (Controller1.ButtonR2.pressing()) {
} else if (!Controller1RightShoulderControlMotorsStopped) {
Elevator.stop();
// set the toggle so that we don't constantly tell the motor to stop when the buttons are released
// check the ButtonUp/ButtonDown status to control High_Intake
if (Controller1.ButtonUp.pressing()) {
Controller1UpDownButtonsControlMotorsStopped = false;
} else if (Controller1.ButtonDown.pressing()) {
} else if (!Controller1UpDownButtonsControlMotorsStopped) {
High_Intake.stop();
// check the ButtonX/ButtonB status to control Mid_Intake
if (Controller1.ButtonX.pressing()) {
Controller1XBButtonsControlMotorsStopped = false;
} else if (Controller1.ButtonB.pressing()) {
} else if (!Controller1XBButtonsControlMotorsStopped) {
Mid_Intake.stop();
// wait before repeating the process
wait(20, msec);
return 0;
* Used to initialize code/tasks/devices added using tools in VEXcode Pro.
* This should be called at the start of your int main function.
void vexcodeInit( void ) {
task rc_auto_loop_task_Controller1(rc_auto_loop_function_Controller1);
int main() {
// post event registration
// set default print color to black
printf("\033[30m");
// wait for rotation sensor to fully initialize
wait(30, msec);
vex::task ws1(whenStarted2);
vex::task ws2(whenStarted3);
whenStarted1();
Here is the Output when trying (and failing) to upload the code to the Brain:
[info]: Saving Project …
[info]: Project saved!
windows build for platform vexv5
“LINK build/52718B.elf”
build/src/robot-config.o:(.bss.Brain+0x0): multiple definition of `Brain’
build/src/main.o:(.bss.Brain+0x0): first defined here
build/src/robot-config.o:(.bss.Controller1+0x0): multiple definition of `Controller1’
build/src/main.o:(.bss.Controller1+0x0): first defined here
build/src/robot-config.o:(.data.Controller1RightShoulderControlMotorsStopped+0x0): multiple definition of `Controller1RightShoulderControlMotorsStopped’
build/src/main.o:(.data.Controller1RightShoulderControlMotorsStopped+0x0): first defined here
build/src/robot-config.o:(.data.Controller1UpDownButtonsControlMotorsStopped+0x0): multiple definition of `Controller1UpDownButtonsControlMotorsStopped’
build/src/main.o:(.data.Controller1UpDownButtonsControlMotorsStopped+0x0): first defined here
build/src/robot-config.o:(.data.Controller1XBButtonsControlMotorsStopped+0x0): multiple definition of `Controller1XBButtonsControlMotorsStopped’
build/src/main.o:(.data.Controller1XBButtonsControlMotorsStopped+0x0): first defined here
build/src/robot-config.o:(.bss.Drivetrain+0x0): multiple definition of `Drivetrain’
build/src/main.o:(.bss.Drivetrain+0x0): first defined here
build/src/robot-config.o:(.bss.Elevator+0x0): multiple definition of `Elevator’
build/src/main.o:(.bss.Elevator+0x0): first defined here
build/src/robot-config.o:(.bss.High_Intake+0x0): multiple definition of `High_Intake’
build/src/main.o:(.bss.High_Intake+0x0): first defined here
build/src/robot-config.o:(.bss.LeftDriveSmart+0x0): multiple definition of `LeftDriveSmart’
build/src/main.o:(.bss.LeftDriveSmart+0x0): first defined here
build/src/robot-config.o:(.bss.Low_Intake_L+0x0): multiple definition of `Low_Intake_L’
build/src/main.o:(.bss.Low_Intake_L+0x0): first defined here
build/src/robot-config.o:(.bss.Low_Intake_R+0x0): multiple definition of `Low_Intake_R’
build/src/main.o:(.bss.Low_Intake_R+0x0): first defined here
build/src/robot-config.o:(.bss.Mid_Intake+0x0): multiple definition of `Mid_Intake’
build/src/main.o:(.bss.Mid_Intake+0x0): first defined here
build/src/robot-config.o:(.data.RemoteControlCodeEnabled+0x0): multiple definition of `RemoteControlCodeEnabled’
build/src/main.o:(.data.RemoteControlCodeEnabled+0x0): first defined here
build/src/robot-config.o:(.bss.RightDriveSmart+0x0): multiple definition of `RightDriveSmart’
build/src/main.o:(.bss.RightDriveSmart+0x0): first defined here
build/src/robot-config.o: In function `vexcodeInit()':
robot-config.cpp:(.text._Z11vexcodeInitv+0x0): multiple definition of `vexcodeInit()’
build/src/main.o:main.cpp:(.text._Z11vexcodeInitv+0x0): first defined here
build/src/robot-config.o: In function `rc_auto_loop_function_Controller1()':
robot-config.cpp:(.text._Z33rc_auto_loop_function_Controller1v+0x0): multiple definition of `rc_auto_loop_function_Controller1()’
build/src/main.o:main.cpp:(.text._Z33rc_auto_loop_function_Controller1v+0x0): first defined here
make: *** [vex/mkrules.mk:18: build/52718B.elf] Error 1
[error]: make process closed with exit code : 2
Here’s the Terminal in case anyone’s interested. It doesn’t update when I try to download the code:
v5terminal V1.0
Device: COM10
v5terminal exit
v5terminal V1.0
Device: COM10
v5terminal exit
v5terminal V1.0
Device: COM10
COM10: No error
v5terminal V1.0
Device: COM10
v5terminal exit
v5terminal V1.0
Device: COM10
v5terminal exit
v5terminal V1.0
Device: COM10
v5terminal exit
v5terminal V1.0
Device: COM10
v5terminal exit
v5terminal V1.0
Device: COM10
/ Module: main.cpp/
/Author: C:\Users\lrhoda0178 /
/Created: Sat Jan 23 2021/
/ Description: V5 project /
// Elevator motor 8
#include “vex.h”
#include “robot-config.h”
int main() {
vexcodeInit();
float myVariable;
// “when started” hat block
return 0;
while (true) {
else {
else {
Elevator.stop();
High_Intake.stop();
Mid_Intake.stop();
wait(5, msec);
return 0;
while (true) {
else {
else {
wait(5, msec);
return 0;
brain Brain;
while(true) {
Elevator.stop();
// set the toggle so that we don’t constantly tell the motor to stop when the buttons are released
High_Intake.stop();
Mid_Intake.stop();
wait(20, msec);
return 0;
int main() {
printf("\033[30m");
wait(30, msec);
whenStarted1();
Formatted Code
As for why your program is not working, some of the stuff in your code is already in robot.config,cpp. Also, you don’t have a preatuon function or a driver control function. I would recommend just recreating the code in VEXcode V5 Pro rather than simply copying and pasting it into the file.
Thank you, I deleted the robot.config.cpp, and it works
Happy Cake Day! 20char
