Hi there. Im new at coding and tried to Download the following Code to my vex v5 Brain. However appears every time the exit code and another (older) programm runs on the Slot wich I haven‘t selected.
Pls help me
/* Module: main.cpp */
/* Author: Konrad */
/* Created: 1/1/2025, 4:09:38 PM */
/* Description: V5 project */
#include "vex.h"
using namespace vex;
competition Competition;
// VEXcode device constructors
brain Brain;
// Drivetrain
motor LFDrive = motor (PORT20, ratio18_1, false);
motor RFDrive = motor (PORT11, ratio18_1, true);
motor LBDrive = motor (PORT19, ratio18_1, false);
motor RBDrive = motor (PORT17, ratio18_1, true);
// floatband
motor floatband1 = motor (PORT16, ratio18_1,false);
motor floatband2 = motor (PORT9, ratio18_1,false);
// leverdown
motor leverdown = motor (PORT14, ratio18_1, false);
// arm
motor arm1 = motor (PORT15, ratio18_1, false);
motor arm2 = motor (PORT13, ratio18_1, true);
// controller
controller Controller1 = controller(primary);
/* Pre-Autonomous Functions */
/* You may want to perform some actions before the competition starts. */
/* Do them in the following function. You must return from this function */
/* or the autonomous and usercontrol tasks will not be started. This */
/* function is only called once after the V5 has been powered on and */
/* not every time that the robot is disabled. */
void axisthreechanged() {
LFDrive.spin(forward, Controller1.Axis3.value() * 0.5, pct);
LBDrive.spin(forward, Controller1.Axis3.value() * 0.5, pct);
RFDrive.spin(forward, Controller1.Axis3.value() * 0.5, pct);
RBDrive.spin(forward, Controller1.Axis3.value() * 0.5, pct);
void axisonechanged() {
LFDrive.spin(forward, Controller1.Axis4.value() * 0.5, pct);
LBDrive.spin(reverse, Controller1.Axis4.value() * 0.5, pct);
RFDrive.spin(reverse, Controller1.Axis4.value() * 0.5, pct);
RBDrive.spin(forward, Controller1.Axis4.value() * 0.5, pct);
void floatbandfor() {
floatband1.setVelocity(100, pct);
floatband1.spin(forward);
floatband2.setVelocity(100, pct);
floatband2.spin(forward);
void floatbandback() {
floatband1.spin(reverse);
floatband2.spin(reverse);
void leverdownvoid() {
leverdown.spinToPosition(20, degrees);
void leverupvoid() {
leverdown.spinToPosition(150, degrees);
void armdown() {
arm1.spinToPosition(0, degrees);
arm2.spinToPosition(0, degrees);
void armbasic() {
arm1.spinToPosition(90, degrees);
arm2.spinToPosition(90, degrees);
void pre_auton(void) {
/* Autonomous Task */
/* This task is used to control your robot during the autonomous phase of */
/* a VEX Competition. */
/* You must modify the code to add your own robot specific commands here. */
void autonomous(void) {
// Insert autonomous user code here.
/* User Control Task */
/* This task is used to control your robot during the user control phase of */
void usercontrol(void) {
while (1) {
// This is the main execution loop for the user control program.
// Each time through the loop your program should update motor + servo
// values based on feedback from the joysticks.
// Insert user code here. This is where you use the joystick values to
// update your motors, etc.
// prevent wasted resources.
// Main will set up the competition functions and callbacks.
int main() {
// Set up callbacks for autonomous and driver control periods.
Controller1.ButtonR1.pressed(floatbandfor);
Controller1.ButtonR2.pressed(floatbandback);
Controller1.Axis1.changed(axisonechanged);
Controller1.Axis3.changed(axisthreechanged);
Controller1.ButtonDown.pressed(leverdownvoid);
Controller1.ButtonUp.pressed(leverupvoid);
Controller1.ButtonA.pressed();
Controller1.ButtonB.pressed();
Controller1.ButtonX.pressed();
// Run the pre-autonomous function.
pre_auton();
// Prevent main from exiting with an infinite loop.
while (true) {
wait(100, msec);
edit: code tags added by mods, please remember to use them.
