Error or on purpose
When using the vex hub calculator the lowest score is 0 if you say blue has some in the negative corner but none in the positive corner it says they have 0 points. Is this a mistake?
Not a mistake, a team can’t have negative points (see SC6)!
No, as the negative corner only makes pre-existing scored rings negative, so if blue had negative 2 points from a corner but only had scored a single point on a goal, they would have 0 points and not negative.
