Error when downloading a no gyro program?
I would re set up your drivetrain and make sure when you set it up your clicking “No Gyro”
Tried that multiple times and it still doesn’t work
Quit and relaunch VEXcode, it should fix itself.
VEXcode has a bug where if a gyro/imu is removed from the drivetrain, the code generator still creates the gyro/imu calibrate call. Quit and relaunch usually fixes this issue.
Hasn’t worked after relaunching, we’ve had this problem for 3 practices now
Can you post the file?
Make sure there are no spaces in the name of the program.
Ho do I do that………………….
Just drag the file into your post where you woild type and it will be added as an attachment.
